Question about Acer AC 711 17" CRT Monitor
CRT Voltage Pin Voltage
Model Acer AC711 17" Monitor CRT Voltage
  • 98 Answers
What is the problem? Can't fix without info.
Posted on Dec 25, 2007
Substitution ic NT6812K-20012
Posted on Jul 17, 2008
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
the circuit that maintains voltage to the color for the red color is weak and has possible weak or defective parts that need replacement. In this case it could be the high voltage tranformer or regulator at the color compensator circuit that maintains the balance of the color or color pins at the CRT tube. They are becoming weak and the tube may need replacement.
Jul 19, 2010 | Acer AC 713 17" CRT Monitor
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
Screen goes white
check the -ve ground voltage (we called it G1) on the card back side of CRT gun. the 1 or 2 no. pin. when u switch on it the voltage must be between 40 to 60 in negetive. if don't then follow the track and replace the controller transister. also the electolytic capacitor in that line....change the filter near EHT transformer. (that might be 10mfd/250 volts DC). used to filter that negitive supply.
if the monitor is compaq or samsung model then it is different.
for that u have to tell me then i will tell u....
Feb 08, 2008 | Gateway FPD2275W LCD Monitor
Sony Model: SDM-HS73
Check the screen voltage and dry solder on the CRT base board.
Jan 06, 2008 | AcerView 78ie 17" CRT Monitor
No Image
Typical failure is High voltage supply. Can you hear a high pitch whine or the relay click on and off? You will need some test point reffence voltages for the board and confirm you do not have a damaged VGA cable. It is not easy to give step by step via forum. Google "monitor repair", there were a couple good general guides that are printable. If youe high voltage tranformer (flyback) is gone, do not go any further. Price of a monitor flyback is $65 to over $100 depending on model.
Apr 09, 2007 | Acer AC711B 17" CRT Monitor
Help on monitor repair
Have you checked the horizontal output transistor for a short or leakage?? most of these sets will not start up unless the horizontal sweep sends the pulse to the power supply and says start me up!! I would look at bthe drive as well on the horiz. curcuit. If theres a pulsating voltage that means its waiting for something to signal it to work or its missing something.. Good luck
Apr 17, 2006 | AcerView 78ie 17" CRT Monitor
Acer AC 711 17" CRT Monitor Logo
233 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
