my friend gave me an LG lightscribe super multi DVD rewriter it worked fine in her com but wen i took my com apart and installed it my com wouldnt turn on all of the wires were connected properly and it still wouldnt work no lights no fans no beeps. so i took it out and put back the original cd writer into it and turned it on and works fine again someone please help
you prolly had the jumpers on the new dvd drive improperly set, you want them set to cable select for most cases.
if, on the top or bottom of the dvd drive, it does not have a diagram of which jumper is the master, slave or cable select (usually labeled, cs), then you will haver to look it up in the manual.
if you were connecting the drive to a ribbon cable that is shared with another drive, both drives on that cable must be set to cable select, or one must be set as master, and the other as slave. if there is another drive (optical or hard drive) on that cable, and it is set to the "master" position, the new drive will have to be set to "slave" OR both drives will have to be set to cable select. if you connected the optical drive (set to cable select) to the same cable as the computers primary hard drive (the drive which boots it) and the hard drive is set to master, then it may not boot, until both are set to cable select, or one is set master, and the other, slave.
the other possibility is that you have exceeded the capacity of your power supply, but that is highly unlikely.
Was this helpful?
Yes
No
Popular Solutions for HP Hewlett Packard Pavilion?
HP Hewlett Packard Pavilion? Slimline S3100N PC Desktop
recently installed binatone S1545 onto computer running xp home. works well but unable to stream...
(More)
recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your sound card unable to play''
Cannot boot up Stop Errors - Kmode-Exception Not_Handled Address BECD4B79 base at BECCD000 Datastamp...
(More)
Cannot boot up Stop Errors - Kmode-Exception Not_Handled Address BECD4B79 base at BECCD000 Datastamp 425CD8E1 - rt2500usb.sy Could you please advise Thank you very much, Diane
