Question about Onkyo TX-SR601 Receiver
No sound volume wont adjust, it got stuck on highest setting which is 99,no sound coming from the speaker,all remote function work, tried to adjust the volume control through the manual knob, still dont work
  • sendra Jan 03, 2008
    Same problem, doesn't work with headphones either, vol stuck in 99
  • zeropiston Aug 25, 2008
    exactly same problem
  • 1,512 Answers
Hi guys
It sounds like the unit has locked up from a power flip type situation. I suggest powering the unit down completely overnight and then fire it up again in the morning and see how it behaves. Some of your system menu presets may have lost their settings and may need to be setup again also. Get back to me here if you have the same condition after doing a full reset in this manner.
regards
Graeme
Posted on Mar 08, 2008
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
Good morning -- I am having an issue with my volume - I have it on the highest possible, but my speakers aren't able to pick up much still
Does any sound at all come out of your speakers?
1. Go to Start > Control Panel > Sounds and Audio Devices
2. Under the volume tab, turn your "Device Volume" bar up
3. Also, click on "Speaker Volume" at the bottom and adjust both left and right speaker bars up
Jul 20, 2011 | HP Compaq Presario SR1920NX PC Desktop
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
I have an Onkyo tx-sr605 7.1 channel receiver in which I have set up currently with only with 5.1 channel. The system sounds great, but I am finding that when I set the volume to a level to hear the...
After a long effort searching on Google, I found a solution. There is a Late night setting on the remote that limits the loud sounds scenes so it is not much loader than the dialog. Works great, I can't believe I never notice the button before.
Jan 20, 2010 | Onkyo TX-SR605 Receiver
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
My vizio tv speakers are busted, how can i replace them
You can not use external speakers unless they are part of a home theater equipment (or similar device), I recomend you to try to adjust the volume settings in your TV first.
Jul 01, 2009 | Vizio VX32L Television
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
Sansui tv/vcr combo is stuck on highest volume.
If you have the remote,have you tried it ?
Have you tried the volume button on the front of the set ?
If neither the remote or the button will work, then you may have a problem with the microprocessor IC (system control). If this is the case, then the set might not be economical to repair.
Perhaps the volume "up" button is stuck ?
Feb 08, 2008 | Sansui COM312AD 13" TV/VCR Combo
No Sound - LCD Volume says 99
Found a solution that works. Power down the receiver. Unplug it from the wall. Wait 10 minutes. Plug it back in and power it back up. Worked like a champ to fix this exact problem with my TX-SR601.
Nov 10, 2007 | Audio Players & Recorders
Onkyo TX-SR601 Receiver Logo
317 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
