Kenmore Washer won't Agitate
Kenmore 70 series
Model# 110. 20712 991
Serial# cc 0352576
Part# 3953326
Type 111
Washer will fill with water then washer will try to agitate. Agitator will move some but it is not operating correctly. During this stage there is also a constant noise (sounds like a lawn mower running but not as loud). Tried to drain the water via selector switch but will not drain.
  • dougboren Jan 22, 2009
    The agitator spins freely when turned by hand, without turning the bottom part of the agitator mechanism. It doesn't seem to turn at all during wash cycle,
  • 183 Answers
Gearbox internal fault, major repair, not really a do it yourself job.
Posted on Dec 25, 2007
Needs a motor, not a lid switch, not a transmission, not a coupler , not a pump , not a timer , a motor....get it?...a motor
Posted on Oct 19, 2011
Kenmore washer won't spin or agitate. Sounds like it wants to but can't.
Does the washer fill with water then stop and hum? The problem may be in the timer or processor or it could be the switch that confirms the lid or door is closed.
May 30, 2012 | Kenmore Washing Machines
Washer Kenmore 70 Series Model # 110.247323000 Serial# CR3845255 Type 111 Washer fills cold, warm, hot - no agitation - no draining
IF THE MOTOR DOES NOT RUN CHECK THE LID SWITCH. IF YOU HEAR IT RUNNING YOU MAY HAVE A BAD COUPLER.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
938 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
