Question about Acer Aspire One PC Notebook
HP DV2000 DVD CD ROM ejects
i am having problem with my DVD CDROM which came with HP Pavilion DV2000 system. It keeps ejecting the drive. and sometimes it does not recognize CD.
Please help me to resolve the problem.
  • 1 more comment
  • Anonymous Mar 30, 2008
    Pressure on the top near mouse is somehow ejecting the drive.
  • jliaou Jul 29, 2008
    I also have an HP DV2000 and it's doing the same thing with the disc drive ejecting
  • Anonymous Feb 02, 2009
    same as described! any solutions?
    Problem Solver:
  • 30 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 19, 2010
Check the system hardware properties.
right click on my computer icon --> choose Properties
System properties will pop up. go to Hardware tab --> click on Device manager. there all the hardware install on yr machine will display choose your DVD drive and check the property of drive.
if it is working file.
you just update your dvd drive. iether from web or from a driver cd came with your machine
Posted on Dec 25, 2007
Dv9815nr cd rom eject button
Yes there is. Open My computer and right click the CD ROM Drive icon and click Eject. This way you can eject your Optical Drive Tray.
Aug 10, 2012 | HP Pavilion dv9815nr Laptop
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
on May 12, 2010 | Computers & Internet
Create a Shortcut or Hotkey to Eject the CD/DVD Drive
Create a Shortcut to Eject the CD/DVD Drive
Right-click on the desktop or elsewhere and choose New \ Shortcut.
In the location box, put the full path to the nircmd.exe file that you downloaded, and append the "cdrom open" command to the end of it, adjusting the drive letter to match your disc drive:
"C:\path\to\nircmd.exe" cdrom open D:
Note the location of the quotes.. if you are using a path with spaces in it, you need to make sure the quotes are only around the path to the executable, and the arguments should be placed after the quote.
Give the shortcut a meaningful name, like Eject CD or something like that, and you'll have a new icon (read below on how to use the cd-rom icon as shown)
Create a Shortcut to Close the CD/DVD Drive
You can follow the same exact instructions as above, but instead of "cdrom open" just substitute "cdrom close".
Assign a Hotkey to the Shortcut
Now that we have a shortcut, we can assign a hotkey to the shortcut by right-clicking on the icon and choosing Properties. On the Shortcut tab you'll see a place to assign the Shortcut key:
on Apr 29, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
My cd rom drive has power but when you try to eject the tray it won't go laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
Hello My Hp pavilion dv2000 is ready for vista but nowadays i install windows 7 home edition and after install my cd/dvd rom icon don't show in my computer. i try to solve this by removing disk drive...
Go to Control Panel-->Administrative Tools-->Computer Management
Your CD/DVD rom would be listed there... Just right click on the DVD rom and select"Change drive letter and path". Then select "Add" and change the drive letter..
Oct 06, 2010 | Computers & Internet
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
My dvd and cdrom in Compaq Presario R3000 quit working. Help!
Unfortunately these devices will fail.
A new one will cost in the $20-30 range and is easy to install.
Mar 20, 2009 | Compaq 350831-001 - Presario R3000 Series...
Compaq Presario V2000
somthing thats worth trying is going into my computer, right click on the cdrom drive and click eject if it works that way then its software thats stopping it from ejecting, if it still dont work take a paperclip and push it in the small hole in the cdrom drive and it will pop out its only a temporary thing but it works to get the cd out.. All the Best John
Mar 07, 2007 | Compaq Presario 1200,1600 (297657-001)...
Acer Aspire One  PC Notebook Logo
378 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
