I had HP-LJ152nf turn off & on several times but same error appears on screen therfore unable to rpint.
Appreciate help from someone who had simialr problem/s
Thank you.
Peter
SOURCE: HP MFP 1522nf turns on and display error 49 turn
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
[email protected]
SOURCE: I have hp 1522nf printer & it is showing
Hello ! you can try doing the following:
1. Please ensure that the printer is directly connected to wall outlet.
2. Print a configuration page and check the firmware datecode. If possible update printer firmware and check if the issue occurs.
3. If the issue occurs, please perform a restore factory defaults. Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number.
a. On the product control panel, press Setup .
b. Use the arrow buttons to select Service, and then press OK.
c. Use the arrow buttons to select Restore defaults, and then press OK. The product automatically restarts.
4. If the issue still persists, perform a NVRAM initialization. An NVRAM initialization will return the following device settings to the factory-set defaults:
a. Turn off the product.
b. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
c. Wait until the message Permanent storage init. appears, and then release the buttons. When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Try the following: got to the menu (the wrench) and with the arrows look for service, press ok and look for restore defaults. After that unplug the fax line (this is very important). Go to the hp website and download the firmware update and run it (while updating dont to anything to the printer, no print, copy, fax.) when that is completed try to fax again this should resolve it. If not I recomend to contact a service center, it could be the formatter (the motherboard)
