Question about Konica Minolta magicolor 2400 Laser Printer
Magicolor no longer grabs thicker papers
My Minolta Magicolor 2400W no longer grabs the thicker paper stocks it used to. Now it only grabs thin plain paper. I tried setting the printer driver paper type to "thick stock" but that didn't work. Is there some adjustment I can make to get it to grab again?
    Champion:
  • 214 Answers
I think you need to clean take up roller first, and then set the settings in printer propertis in thick paper.
shold work.
cleaning:
open cover, remove imagine unit, then you can see the take up roller. clean it.
Posted on Jan 11, 2008
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Won't take paper into printer tray lifts up like
Paper tray roller mite need to be clean or replaced so as to grab the paper.
Feb 21, 2011 | Minolta magicolor 2400W Laser Printer
Dear all, When I try to print on printer Magic Color 24300DL it does not "grab" the paper in the tray. It makes some tries, "rolling" but without any succes.Then I get a Media Jam Tray 1 error,...
I fixed the problem with the machine not grabbing the paper.....I simply opened the main lid and then reached in and pulled out the triangular insert (DRUM?) and then when you look inside all the way to the bottom....you will see the rubber tongue that actually grabs the paper.....more than likely it will be dried out or dirty. If you clean it VERY carefully with a soft moist towelette maybe very little soap....it should clean back to grabbing again...of course I went another step forward and put Take Hold fingertip grip and massaged it into the rubber.......been working great ever since. Thicker stock I have to help with my finger.....but all regular stock should work just fine.....
Aug 09, 2010 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Konica Minolta Magicolor 2530DL
Open the top cover of the printer and remove the drum (piece with long green handle). Look down inside the printer and you will see a roller with ridges. Clean that roller with formula 409. Try not to use alcohol because it dries the roller.
If you are printing on paper thicker than 23lb. bond, you want to make sure you select "thick stock" for the media type on your computer.
For instance... in your application click on file and then print. In the print window select properties (usually). On the setup tab of the next window you will see media type on the right side. Set it to the type of paper you are printing on. This should make the printer pick up the paper slower.
If the paper is thicker than 90lb index (160 g/m2) it is too thick to go through the machine.
May 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Printing avery labels
You need to change the paper settings from plain to something thicker. The toner is not being heated properly for it to fuse to your paper. It needs to run at the correct speed and temperature in order to adhere properly.
Set it to a heavier stock.
Apr 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
151 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
