Question about GE Profile JTP56 Electric Double Oven
Oven bulb We don't know how to get the cover off of the bulb in the oven.
I have a ge profile double oven and the glass cover on the top convection oven is held in place by grooves that latch onto the glass dome cover. Just turn the dome so that the handles on the glass dome cover are exposed. I used a flashlight and a screwdriver to push the dome to one side.
Posted on Jan 04, 2008
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
How to get light cover off inside oven
Hi Not knowing the type of oven , I can only think it must be a screw type, try turning it to the left of course don't turn it too hard in case it comes out some other way , when yo replace the bulb wipe it off with a clean towel to remove your finger marks on the bulb it will last twice as long by doing this
Dec 07, 2011 | Ovens
How to change oven lamps on Stoves 600EF oven
Well if it is the same as the 720, you will find a small recess in the leading edge of the glass lens/cover. Using a blunt screwdriver, insert it in the slot and twist it. The lens should gradually come away from the side of the oven. DO NOT attempt to do this if the oven has been in use as the lenses will become too hot to handle. Put a cloth on the bottom of the oven to catch the lens as it falls to protect it. Note that there may be a cut out on the inside of the lens to go over the edge of the bulb/bulb holder, so don't try to put the lense back round the wrong way.
Nov 08, 2011 | Stoves 720EF Electric Double Oven
Where can i buy new bulbs for the lower section of my oven???
Any good electrical retailer should have oven lamps. They need to be "oven lamps" because of the heat. You may wish to take one out to check its size and rating before you buy. All four lamps in the oven are the same. To get them out, you will need to remove the glass cover. To do this you should see a little lip on the edge of the cover facing you from the front of the oven. Insert a blunt screwdriver or something similar and twist it, that should be all the force that is required. If there is oven grease around the cover it may take a little more effort. There are cut outs on the glass to allow for the bulb. ALSO, don't attempt to do it if the oven has been used because the covers get very hot. When the oven is cold, briefly turn the switch to the first position to put the lights on, without the heating fan. Have a look to see what to do and you should be OK.
Sep 05, 2011 | Stoves 720EF Electric Double Oven
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
How to fit oven bulb
You should have a glass cover over the bulb itself. It may either screw on or it may have 2 or 3 screws at the base of the glass to take out. Then you should be able to unscrew the bulb as you would any other light bulb in your house. You will want to replace it with another appliance bulb 40 watt. If you have another type bulb or set up in your oven let me know and we will work through it.
Feb 11, 2009 | Stoves Ovens
GE Profile JTP56 Electric Double Oven Logo
243 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
