Boot from the "System Restore" CD-ROM.
One of the "setup" options for XP (or for Vista) is to "format" the entire disk-space, before continuing with the re-install.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony VAIO PCG-K35 PC Notebook
I tried to download Avnex Virtual Audio Device but a windows error occured and said that it hasn't...
(More)
I tried to download Avnex Virtual Audio Device but a windows error occured and said that it hasn't been tested by Microsoft for compatability with Windows XP, it gave me two options, to either continue anyway, or to stop. If I continued, it could ruin my system immediately or in the future. At least that's what it said. I really need this download to get my AV Voice Changer to work.
ok basically i got this laptop for free off a friend who said if i can fix it i can keep it. I know...
(More)
ok basically i got this laptop for free off a friend who said if i can fix it i can keep it. I know nothing about this laptops history, however i noticed the power connector was broken, so this has been replaced. Now it has power it will turn on but when i try to go into the bios it turns off. I removed the fan and heat sink when i changed the connector but i'm pretty sure i fitted it correctly and cleaned it and used thermal compound so i dont think its getting too hot. Still doing more testing but stuck right now.... Any thoughts :)
Batt PCGA-BP2EA any aftermarket batt did not work because
the chip set in the original battery...
(More)
the chip set in the original battery handshakes with the pc. Only
solution was to separate the original battery pack with a screwdriver remove
the two tiny screws under the small rubber rivets and do your best to pry the
battery apart without damaging the chips and the board that runs along the
length of the battery near the connector side. Then rip apart an
aftermarket battery and unsolder the four terminals that connect to a similar
board as in the oem and solder them to the old battery board. This now
works without having to change anything on msconfig.exe since this didn't work
for me. Caution when prying the original battery apart the cells have
some rubberized glue that may take some hard prying to get it open. Just don?t
damage the board and it should work even if you have to electrical tape the
case together. Hope this helps.
