Question about Motorola Mobility RAZR V3c Cellular Phone
Screen Issue My phone is locked on the screen battery charging, even though I have removed the charger plug and tried to turn off/on.
  • 46 Answers
Take it to best buy or the store you hot it from and have them give you a new phone, or fix it, but be sure to git your memory stick back so you dont loose all your c\ontacts n "stuff".
Posted on Dec 27, 2007
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
My Android 4 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Oct 07, 2012 | Cell Phones
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
The cell phone will not open even though the battery is charged
remove the battery then insert it again and then put the charger plug into your phone then press the power switch. Then phone will be turned on but only white screen, don't worry if this situation has done. Leave the phone for while it will turn on completely after few minutes.
If the phone will not turned on ( the screen will not go white) then go to service center they will update your phone's firmware.
Mar 05, 2011 | Nokia N96 Smartphone
Samsung SGH D807 Charging Problem and no screen display
Have you try to use another similar charger to charge your phone to see if it ill charge? because it could be that your charger is bad,. But if you have done that and it is same thing, it means the charging port of your phone is malfunctioning, that is why you have to use repetitive effort before it can charge.
Your battery is not charge due to the bad charging port of your phone, so your phone battery can not hold charge.
To resolve 1 and 2 problem of your phone, all you need to do is to change the charging port of your phone in other for your phone battery to charge and for your battery to charge.
Replace the charging port as said and you will see that your phone battery will charge.
For your screen, is it that the entire screen is black that you cannot see anything, not even text or see names from your contact? if it is, what you need to do is to change the flex on the the screen of your phone and you will see that your screen will display as you want it.
Take care.
May 04, 2010 | Samsung SGH-d807 Cellular Phone
Unlocked Nokia 5310 doesn't turn on. I just gave up my iPhone (got a blackberry from work) and started using this phone again. Worked fine the first day; the next morning I noticed the battery was dead. It...
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
Aug 02, 2009 | Nokia 5310 Cellular Phone
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
Phone charger problem
You should use a genuine sagem charger
Nov 27, 2008 | Sagem My501X Cellular Phone
My MDA won't turn on even when its on the charger.
Apr 11, 2007 | T-Mobile MDA
Motorola Mobility RAZR V3c Cellular Phone Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
