Cars & Trucks Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cam & crank sensor code intermitten spark 2.4
98 pontiac sunfire purchased blown engine installed another replaced timing chain has cam & cranck sensor fault codes double checked timing chain correct will start if holding accelerator wont idle replaced cranck & cam sensors 2times no diff
rtpflh
Level 3:
  • Master 546 Answers
  • Posted on Oct 09, 2009
rtpflh
Master
Level 3:
Answers
546
Questions
Helped
244028
Points
1828
Check timing marks on cam sprocket,could be one tooth 'retarded'.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
7013
Points
49
Are they the same engines? and i mean exactly the same? if the arent the same maybe check and look at the starter ring gear and count the teeth...also check the camshaft sprocket...is it different?
My 2003 Pontiac Sunfire well turn over but will not crank tried spraying gas in the air intake still will not start was running fine now it just wont start even replaced crank sensor and a couple other...
You mean it will turn/crank over, but wont fire.
Check for spark, most likely cause would be crank or cam angle sensor faulty.
Have you checked for obd codes? Is the check engine light illuminated?
What is the correct timing chain installation on 2000 grand cherokee 4.0 engine
the timing marks are to line up and face each other
then fin the chain
then turn the crank until the crank sprocket is facing down timing mark is facing down
the cam mark should be in the 2 oclock position
there should be 15 links between marks
form your description that is what you have done so the problem is not in the timing chain installation
back firing is normally from a valve still open when the spark occurs so check firing order or the distributor installation is not 180 degrees out
Getting p0016 code
Crankshaft Position - Camshaft Position Correlation
What does this mean? OBD Code P0016refers to
The crankshaft position sensor (CKP) and Camshaft position sensor (CMP) work in harmony to control the spark/fuel delivery and timing. They both consist of a reluctor, or tone, ring which passes over a magnetic sensor, which generates a voltage, indicating position. The crankshaft sensor is part of the primary ignition system and functions as the "trigger". It detects the position of the crankshaft relays that information on to the PCM or the ignition module (depending on the vehicle) to control spark timing. The Camshaft position sensor detects the position of the camshafts and relays the information to the PCM. The PCM uses the CMP signal to identify the beginning of the injector sequence. What ties these two shafts and their sensors together is the timing belt or chain. The cam and crank should be precisely timed together. If the PCM detects that the Crank and Cam signals are out of time by a specific number of degrees, this P0016 code will set.
Symptoms Possible sumptoms of OBD code P0016
Malfunction Indicator Lamp (MIL) illumination The engine may run but with reduced performance The engine may crank but not start The engine may exhibit a rattle near the harmonic balancer indicating the tone ring is damaged The engine may start and run, but poorly
Causes Possible causes of OBD code P0016
Timing chain stretched, or timing belt skipped a tooth due to wear Misalignment of timing belt/chain Tone ring on crankshaft slipped/broken Tone ring on camshaft slipped/broken Bad crank sensor Bad cam sensor Damaged wiring to crank/cam sensor Timing belt/chain tensioner damaged
Possible Solutions First, visually inspect the cam and crank sensors and their harnesses for damage. If you notice broken/frayed wires, repair and recheck. If you have access to a scope, check the cam and crank patterns. If a pattern is missing, suspect a bad sensor or a slipping tone ring. Remove the cam gear and the crankshaft harmonic balancer and inspect the tone rings for proper alignment and make sure they're not loose or damaged or that they haven't sheared the key that aligns them. If they are properly installed, replace the sensor. If the signal appears normal, then check the timing chain/belt for proper alignment. If it's misaligned, check for a damaged tensioner that may have allowed the chain/belt to slip a tooth or several teeth. Also check that the belt/chain isn't stretched. Repair and recheck.
1helpful
Ho to change water pump in a2002 pontiac sunfire 2.4 twin cam
It is a $800 job usually because you have to access the timing chain case. So the timing chain is usually replaced with it. To get you started , take off the front pass. wheel then plastic panels to see crank pulley. then jack support motor to take off engine mount. If your not discouraged yet, buy a $25 book and continue with timing chain removal directions. This is no easy job. I take 10 HRS.
2answers
2007 pontiac, solstice cam sensor replacement -is this common?
replace crank senser, first, always replace together, also chk some time double cam motores have to cam sensers.
2helpful
I replaced the timing chain in a 2005 potiac sunfire with a 2.2 and now it run rough but runs fin going down the road but idling it run rough and sometimes will die
if the car ran fine befor you changed the timing chain you may have the cam timing off by one tooth retarted. Being the PCM controls the timing advance . The engine smooths out at higher speeds .Start back tracking and looking at the simple stuff . but you may have to pull the timing housing again to check the timing marks on the cam and the crank
3helpful
Erreur p0016 on sienna 2003 after change t-belt
Symptoms of a P0016 will or may include:
* Malfunction Indicator Lamp (MIL) illumination
* The engine may run but with reduced performance
* The engine may crank but not start
* The engine may exhibit a rattle near the harmonic balancer indicating the tone ring is damaged
* The engine may start and run, but poorly
Causes may include:
* Timing chain stretched, or timing belt skipped a tooth due to wear
* Misalignment of timing belt/chain
* Tone ring on crankshaft slipped/broken
* Tone ring on camshaft slipped/broken
* Bad crank sensor
* Bad cam sensor
* Damaged wiring to crank/cam sensor
* Timing belt/chain tensioner damaged
Possible Solutions:
1. First, visually inspect the cam and crank sensors and their harnesses for damage. If you notice broken/frayed wires, repair and recheck.
2. If you have access to a scope, check the cam and crank patterns. If a pattern is missing, suspect a bad sensor or a slipping tone ring. Remove the cam gear and the crankshaft harmonic balancer and inspect the tone rings for proper alignment and make sure they're not loose or damaged or that they haven't sheared the key that aligns them. If they are properly installed, replace the sensor.
3. If the signal appears normal, then check the timing chain/belt for proper alignment. If it's misaligned, check for a damaged tensioner that may have allowed the chain/belt to slip a tooth or several teeth. Also check that the belt/chain isn't stretched. Repair and recheck.
Other crank sensor codes include P0017, P0018, P0019, P0335, P0336, P0337, P0338, P0339, P0385, P0386, P0387, P0388, and P0389.
Hope helps.
6helpful
3.6 in a 2006 pontiac g6 is throwing code p0017 is this crank sensors or what is the most common fix
P0017 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
The crankshaft sensor is part of the primary ignition system and functions as the "trigger". It detects the position of the crankshaft relays that information on to the PCM or the ignition module (depending on the vehicle) to control spark timing. The Camshaft position sensor detects the position of the camshafts and relays the information to the PCM. The PCM uses the CMP signal to identify the beginning of the injector sequence. What ties these two shafts and their sensors together is the timing belt or chain. The cam and crank should be precisely timed together. If the PCM detects that the Crank and Cam signals are out of time by a specific number of degrees, this P0017 code will set.
Symptoms of a P0017 will or may include:
Causes may include:
* Bad crank sensor
* Bad cam sensor
Possible Solutions:
Other crank sensor codes include P0016, P0018, P0019, P0335, P0336, P0337, P0338, P0339, P0385, P0386, P0387, P0388, and P0389.
Hope this helps (remember to rate and comment this answer).
2helpful
2answers
Does my 2003 pontiac sunfire ecotec motor have a cam sensor? Where is it? If it starts as soon as u give it gas it cuts out. I've replaced: fuel pump, fuel filter, coil pk, spark plugs, crank sensor,...
there is still more to check. like the mass air flow sensor, the whole fuel line cleanout, and if its an auto it does have a camshaft sensor. its located into the transmission.
Need timing marks 2.4 sunfire after installing water pump
YOU WILL SEE A HOLE IN THE CAM GEAR THAT A 3/8 BOLT WILL FIT INTO. PUT A BOLT INTO THE HOLES OF BOTH CAM GEARS. THEN LINE UP THE CRANK PULLEY KEYWAY AT ABOUT 12 O'CLOCK WITH THE MARK ON THE ENGINE BLOCK.
MAKE SURE TO COMPRESS THE CHAIN TENSIONER AND RELEASE IT WHEN THE CHAIN IS IN POSITION.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
