Question about Logitech X-230 Computer Speakers
Using headphones with Logitech X-230 speakers
I have my X-230 speakers plugged into my TV/video setup. Everything works fine, but when I plug my headphones into the speakers the volume is fixed and can not be changed up or down. Is this because the speakers are designed for computer use and for computer-style volume control? Is there any way of changing the volume through the TV/video system?
  • FOG-57 Dec 26, 2007
    Thanx peacepeace
    I'll try the TV menu suggestion to see what happens. Your first comment is disturbing, though - what the hell is the point of a manufacturer providing a headphone socket if we can't change the volume settings? If it's a legal problem, maybe the headphone manufacturers can lean on the speaker manufacturers to come up with a usable compromise. Just a thought.
    FOG-57
    Problem Solver:
  • 16 Answers
I'm sitting here with an open/disassembled pair of X-230 speakers... solution?
None. The audio input level received from input [in this case - your TV] passed to the headphone "port" unmodified. In other words, once you plug in the headphones, it automatically circumvents the Audio Amplifier [located in SubWoofer box], thus giving you the original audio level output on your headphones. Once you unplug the headphones, the Amplifier kicks in again and supplies your speakers with boosted audio signal.
Why is this the case?
Believe it or not, this is actually a feature, not a fault: the original input level of audio is in # MOST CASES # enough to power the standard pair of headphones. If you connected the "lowly" headphones to the mighty-in-comparison AMP, headphones would most likely end being damaged or stop working completely.
Solution:
The ONLY "solution" you can try is boosting or maxing out the volume on your TV [using its controls], which would give you higher level of input audio, thus higher volume on your Headphones.
[I just registered on this site, so sorry about the double post.]
Posted on Feb 16, 2008
Solution:
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
Posted on Dec 26, 2007
    Problem Solver:
  • 5 Answers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Posted on Dec 25, 2007
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
Headphones plugged into TV audio output but speakers don't turn off
use the tv's setup menu to set the audio properties,eg. speakers on or off when headphones are plugged in.
Dec 22, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Hi I have logitech x-230 speakers which i used on my desktop from the day i bought them i now have a mac laptop and tried using them and they wont work, do i need to download anything to have them work?...
no you dont need to download anything on your mac computer.
there are two ports in mac computer one is for mic and one is for your speakers. make sure your are connecting to the right port.
and please check/change the powerpoint of your speakers.
then check it should work now.
Jun 27, 2011 | Logitech X-230 Computer Speakers
Tried to connect to samsung lcd no sound
Plug the green lead on the speakers into the headphone socket on the television. You may need to go into the menu to turn up the headphone output. Turn it to 70% on the TV, then use the volume control on the speakers
Jan 10, 2010 | Logitech X-230 Computer Speakers
Logitech speakers hissing only when headphones plugged in.
The headphone adaptors attach to your computer has a
loose connection. Use another headphone and try.
Send in your e-mail and vote for the solution. Thanks,
Sep 27, 2009 | Logitech X-540 Computer Speakers
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
Connect 2.1 Logitech to a TV
if you have an RCA output for your audio. you can buy a lead that goes from 3.5mm headphone jack into 2 RCA phono plugs.
Feb 25, 2009 | Logitech X-530 Computer Speakers
Logitech x-230 - left speaker not working when used with 360
my speakers plug into my comp. by that little cord with the green end piece. and i have to figit around with it just to get one speaker to work, can i fix it or do i have to buy the whole set again?
Mar 10, 2008 | Logitech X-230 Computer Speakers
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Speakers do not work
yes thats the fact when you plug a headphone into any speakers the head phone will be the only one to function the speaker stops thta the circuit technically which will break the connection of power to speaker if you plug head phone
Jun 29, 2006 | Logitech X-230 Computer Speakers
Logitech X-230 Computer Speakers Logo
1,053 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
