Question about HP Pavilion dv1000 Notebook
HUMM in phone line(modem)
HP Pavilion dv1040us........Started with slight humm in phone line, which continued to get louder to point that modem was unable to connect with service provider and produced a loud humm in the audio. Notebook works fine with 56K PC card modem,or mobile phone tools through USB port, will not work with notebook dsl or phone plugs. Suspect bad solder joint or damaged component part from lightning surge through phone line ???
  • shyboy2146 Dec 31, 2007
    NOT HARDLY.......mother board problem.
  • 310 Answers
Turn off the mic or the extrernal speaker if this dosent work there might be a problem with the phone cord or your house wires
Posted on Dec 31, 2007
I have a humm when deiving it starts at 35-40 and does not get louder at higher speeded but stops when i do
Without hearing it I can't say for sure. Did you recently get a new set of tires with some aggressive tread? Some Mud Terrain tires will humm when driving.
But my guess would be that you probably have a bad wheel bearing. If it is the wheel bearing, it is something that should be taken care of Right Away.
Hope this helps.
Mar 13, 2011 | Avalanche 2003 03
RCA Guide Plus Gold Gemstar 27 inch Entertainment Series has perfect picture no sound. The speakers are ok have tested them. When tv is turned on and dvd player is on shows perfect picture but can only...
On the left hand side of the remote control there is a blue or diferent kind of small sercle round buton (mute) push it once and turn the volume up till you hear the volume.
Nov 06, 2009 | RCA Televison & Video
Audio humm on VIZIO VW32LHDT30A
You have a bad ground through the cable box or cable system. This causes AC to leak into the TV showing up as bars that roll from bottom to top and sometimes audible as well. Have the cable company replace the cable box and/or check out for proper grounding outside at the demarcation point.
Mar 23, 2009 | Vizio VW32L 32 in. LCD HDTV
PC Grounding Problem
This ground loop isolator from Radio Shack was suggested when I did a search:
It says it has the 1/8 jack adapter, so it should plug right in!
I'd be curious to hear about the results if you try it.
Good Luck!
Feb 04, 2009 | HP Pavilion Media Center a1330n - AMD...
Video1, video 2 humm
Replace C602 on dvd board. noise on 10v line causing problem.
Jan 19, 2009 | Sony DAV-FC7 System
Loud humm. I have to keep the volume down when watching the TV.
A humm may be caused by a cable TV grounding problem called a "ground loop." Basically, the grounding for the Cable TV line and the power outlet for the TV are at unequal levels. I had this same humm with both the internal TV speakers and with external speakers (headphones, etc.). The 2 solutions are (1) install a Ground Loop Isolator at the TV, or (2) call the cable company to troubleshoot the problem. I figured the time I saved dealing with the cable company was worth the $50 for the part. I installed the Jensen VRD-1FF which has worked perfectly! Ordered from eBay and saved about $12 over the Jensen Electronics web site price. Hope this helps.
Dec 05, 2008 | Bose Lifestyle 28 System
Microwave no heat
The "HUMM" indicates a breakdown in the High Voltage Side. The loud "POP" was the breakdown. You have only four Components in the High Voltage side.
1. High Voltage Transformer. You can eliminate this as the problem. Why? If it was the problem it would have blown the line fuse, and would have given off a burned transformer smell.
2. High Voltage Diode. Usually will Burn or Pop when shorted, but will then OPEN the Circuit and there is no "HUMM".
3. High Voltage Capacitor.This is the Silver Can with the two terminals on top. It can SHORT internaly between the plates (the two terminals) and give the "HUMM".
4. Magnetron. This is my number one suspect. A SHORTED Magnetron.
Feb 03, 2008 | Kenmore 63652 Microwave Oven
HP Pavilion dv1000 Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
