Question about Apple IPod nano Second Generation MP3 Player
Center Button I have an 8 GB iPod Nano that I LOVE, over the last couple months the center button has become harder and harder to press...by this I mean it goes down just fine but it won't cycle through the menus unless I press it really hard. This causes me great pain and anguish because it has become so bad I can hardly use it. HELP! Thanks
  • Apple Master
  • 13,433 Answers
The small button(the actual button) under the plastic menu button ist most likely jammed or broken. It would need to be replaced.
http://www.mp4converter.net/images/upload/ipod-6.jpg
You could open the ipod and check to see whats the shape of the button.
If you have any questions let me know! Good luck.
Posted on Mar 30, 2008
  • Ekse Apr 02, 2008
    If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
    Thanks alot!
    If you need more asistance, let me know.
Green ipod 8gb white screen problem
Try to press the menu and center button at the same time until it restarts. Also try restoring the ipod in iTunes
Jan 14, 2014 | Apple iPod nano 8 GB Pink (3rd Generation)...
IPod nano 8 GB keeps showing the connected mo115851815ving arrows
Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
If this does not resolve your issue please do let me know. I have a fountain of information on iPods
Mar 19, 2009 | Apple iPod nano 3rd Generation
I went to plug up my ipod nano third generation the 8 GB and it is frozen on the last song i listen to and then I unpluged it and went to push play and it wouldn't un-freeze.
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Feb 20, 2009 | Apple iPod nano
Wrong language on ipod
This is simple but good to know.
Select your language.
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
-----John
If that doesn't work go to: http://support.apple.com/kb/HT1824
Nov 24, 2008 | Apple iPod nano
The screen is on, but there is nothing on it
have you tried resetting it?
if not press the center button and the menu button and hold for a couple seconds
And also Make sure you press Center FIRST (hold this down) then press and hold the menu button while keeping the center button held
Nov 21, 2008 | Apple iPod nano
Ipod 2gb locked.
Press the center button while holding down on the menu button. You will see the Apple logo appear.
Your Ipod is now rebooted.
Aug 26, 2008 | Apple iPod nano
Nano 3rd Generation
hold down the center button and the menu button at the same time it should reset itself and it will not erase your music
Jul 14, 2008 | Apple iPod nano 8 GB Pink (3rd Generation)...
30 GB Ipod Video Problem - Its locked
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Nov 27, 2007 | Apple iPod MA446LL/A MP3 Player
Apple IPod nano Second Generation MP3 Player Logo
67 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
