Question about Dell Inspiron 6000 Notebook
Dell 6000 start up problem
When you start machine, operations light is on, machine is running,
the system read light flashes then goes off machine is running but no log on screen
Some times it will happen coz the fan is failed thats y the procesor is over heating, or its because of the hardware problem
Posted on Dec 25, 2007
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Inspiron 6000, screen goes in flashing lines.
you will dust problem in fan cooling system.first remove mother board from laptop( take care esd precations).
1 remove cpu cooling mechanism
2 .remove screws attached to fan and be careful not to damage fan blades.
3. remove the settled dust at the metal fins (use twizer & forced air) refix all the things test it will work
4. if it still doesnot work then graphics chip will have dry solder and requires professional help
May 27, 2010 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 laptop When i press the start button the power lights stay on for about 5 seconds , then it switches off again. I dose not seam to engage the the operating system I would like...
Check that your power supply/AC adpater is plugged in and working. It could be that you are running on the battery only and if the battery is drained, it tries to start then shuts down again.
Feb 11, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
Wiped hard drive and now must reinstall OS and programs.
if the disc you have has scraches on it then your disc wont run,you can have the disc reface for about $5.or try this wash disc with a very soft cloth under runing hot water [not to hot] dry quickly [soft cloth]and try it again while disc is still warm.had to do this myself with my dell oem disk.
dt
Dec 07, 2009 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6400 battery is overheating and light is flashin
Check out this battery site from Dell to see if you have a lemon
www.dellbatteryprogram.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Sep 10, 2009 | Dell Inspiron 6000 Notebook
Display flashes DELL logo on power up and then goes black.
Try pressing Fn + Monitor. It sounds like you have it set to pipe video out to an external monitor.
Hope this helps.
Dec 12, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000 wont start
I had this problem, and I took out the RAM memory cards and put them back in again, and then the computer booted up fine.
Aug 15, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
37 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
