Question about Olympus Stylus 740 Digital Camera
Oops i dropped it! : (
I dropped my camera it didnt hit hard after it dropped i turned it on and it is now stuck with zoom out and will not do anything it apears to be off but i can not turn it on or do anything with it!
  • Anonymous Jun 16, 2008
    How can you fix the camera, when the zoom is stuck out, it won't extend?
    President:
  • 919 Answers
Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $86.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on May 15, 2009
Zoom is stuck and it wont stay on
Have you tried using a fully charged battery?
also, there could be a dust build up or a sand residue stuck inside the lens that it why its having a hard time coming in or out eventually.
Try to hold your camera, with the lens facing down, from your right hand and while turning it on, hit the camera gently on your left palm. Try this several times.
Sep 04, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Zoom error, Fujifilm J150w
I just pulled apart the camera, everything inside was intact. No cogs broken. couldnt find anything to fix (not a camera expert by the way).
In desperation even put some WD40 on the lens barrel - still no luck.
Camera turns on - barrel is stuck out. Wont zoom, wont go back in and wont take a photo.
Daughter's camera and she says she didnt drop it but just saw it on her desk with the lens out...
Would be good if someone could shed some light on the problem.
Jul 05, 2009 | Fujitsu Cameras
Zoom dial stuck
Sounds like damaged zoom buttons.
Mar 20, 2009 | Casio Exilim EX-Z57 Digital Camera
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Lens Stuck open and wont turn on
My daughters Sony Cyber-Shot had the same trouble and I read that many times it is caused by foreign matter getting in the lens gearing. 1st suggestion was to hold the camera firmly in one hand and hit one side into the palm of your other hand. Do the same with the bottom, other side and top. Also spray a jet of air into where the concentric lens parts rotate when it opens. Use some judgment, do not hit on a hard surface or spray directly into the glass lens itself, or try to force any movement.
By combining these actions repeatedly I was able to get the camera to first open up and then zoom properly, just as other Sony customers had, Yea ! I then remembered that she was at the beach the day before so when I gave it back to her I guessed that she dropped it in the sand. She had of course.
Good luck, it worked for me
Jmatt
PS Make sure battery is charged :).
Nov 24, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
Zoom lens stuck
Hummmmmm.......I guess it all depends on how hard the drop was. At this point, you have nothing to lose by tinkering around with it.....but my guess would be that it's taken it's last picture. You might try locating a camera repair shop, or even an independent jeweler. They might could at least take a look at it and give you a second opinion. Hope this helps, and sorry about the bad luck!!!!
Chad
Oct 11, 2008 | Canon PowerShot SD850 IS Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Elura 60 Zoom Problem
Guys, so weird but on another site it offered this suggestion: banged the base of your camera against something hard and it will become unstuck. So bang the base of your camera against something hard and it will work again, at least it works like it did but not sure for how long. Good luck. I can't believe that worked. Give it a try. I didnt hit it too hard either.
Dec 20, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Nov 19, 2007 | Fuji FinePix Z2 Digital Camera
Olympus Stylus 740 Digital Camera Logo
107 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
