Question about Watches
Casio pathfinder SPF 70-s titanium band adjustment
Hello and Seasons Greetings! I am stumped on how to adjust the Casio Pathfinder SPF 70-s titanium band. If you can help me through this, I will be sooo grateful! The band has arrow on the segments pointing to the right if the watch is face down. Please help! Thank you in advance for your time and effort in helping a watch band adjustment challenged person :) Many thanks! Misty Casio Protrek
3 Suggested Answers
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
The schlatter.org solution is for the other type of casio band I've run into.
The wristband with the arrows has a fine pictorial solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band
Basically you use a very very fine poker to poke the pins out in the direction of the arrows.
NOTE: you can't poke them out if you will drive them into your work surface, so think about that before you start.
Posted on Feb 02, 2008
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
Do you have a wrist band for SPF-70 Casio Sea Pathfinder
NO-- we do sell anything
if you need a wristband see your local jeweler
Apr 19, 2016 | Casio Watches
Casio sea pathfinder sp60d reset
You need to open the watch and cortocircuit 2 points into the watch machine.
TicTacArea.com is Officla Casio Dealer
Casio Watches
Aug 19, 2014 | Casio Sea Pathfinder Triple Sensor SPF-60
Where can I get a replacement band?
Ebay is a great place for special watch bands. this one is $30:
http://www.ebay.com/itm/CASIO-SEA-PATHFINDER-WATCH-BAND-BLACK-SPF-40-/330812864375?pt=LH_DefaultDomain_0&hash=item4d05fbb777
You can also go to the source, Casio, and purchase a new band:
http://www.casio.com/support/buyparts/
Oct 18, 2012 | Casio Sea Pathfinder SPF70-2V Wrist Watch
How to adjust/identify the correct tide on my sea pathfinder spf-40
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 21, 2011 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I am searching for a replacement strap for my Casio spf-70 sea pathfinder.
<P>Thank you for contacting FIXYA.</P><P>I am forwarding a site to you that you can order through and also for repair should you need in future! Best regards!</P><P>&nbsp;</P><P><A href="http://www.casiosalesandservice.com/istar.asp?a=3&amp;dept=CWBAND">http://www.casiosalesandservice.com/istar.asp?a=3&amp;dept=CWBAND</A></P>
Aug 24, 2010 | Casio Watches
Dec 17, 2006 | Casio G-Shock G7000D-8V Wrist Watch
Watches Logo
393 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
