Question about Brother MFC 210C All-In-One InkJet Printer
All scanned documents have blue background.
When I scan a document or a photo the preview has a blue overall background. If I print the scanned document it comes out with rthe blue tinge all over. However, if I print directly from word or print a photo received by email all the colors are OK and there is no blue tinge. I get the same blue tinge if I insert a photo into word. How do I get rid of this blue tinge?
  • warrenjimbob Feb 12, 2009
    I have an HP Scanjet 5590 and when ever I scan a document it prints out with a blue back ground
  • 832 Answers
You have to take the machine to service partner who can be found on the brother homepage of your country.(
The scanner needs calibration which can only be done by service personel.
Posted on Dec 25, 2007
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
Scanning photo or text image appears with purple/striped background
Nov 18, 2007 | HP Photosmart C3180 All-In-One InkJet...
My sahara Flatbed Scanner works fine except that I cannot find how to print without a "grey:" background. What should I do to print with a clear white background? Eric Schafer. Cape Town RSA.
you will find if you reduce the dpi the scanner is scanning the pictures or documents in, that you will not get a grey background , as you describe, what it is printing is actually the paper itself, if you have it set for say 1200 dpi then reduce it to 600 dpi or even 300 dpi and you will see the difference when you print it
or only select the exact area you want to scan in the document, click preview then move the scan area selection box to exactly fit the picture you want to scan
Mar 27, 2011 | Office Equipment & Supplies
How do I scan with HP psc 1210
Answer is on this link:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP PSC 1210 All-In-One InkJet Printer
I need step-by-stop instructions on how to scan and print a document thats 11X17?
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
as for the printer
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box also you might select print preview where you can look at the size and detail?of the document you are about to print
hope this helps
hope this helps
Dec 01, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I scan a picture and email it?
You can start a scan from your computer or from your HP OfficeJet.
to scan an original from your Windows computer
1 Load your original either on the glass or in the automatic document feeder
2 Press Start Scan.
A scan of the original appears in the HP Preview window.
3 In the HP Preview, you can edit the scanned image. When you have
finished, click Accept.
For more information about making changes to an image during the
preview, see adjust an image during the preview in scan pictures and
documents in the HP Photo & Imaging Help for more information.
The HP OfficeJet does a final scan of the original and sends the image to
the HP Photo & Imaging Gallery.
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
Scanner not scanning right. scans in sections. i need to scan a standard size sheet of paper and it scans it in peices. how do i get it to scan this document correctly
You need to set the scanner to scan a standard size paper (letter or A4) in the Scan Settings dialog. To get there, from the MP Navigator select "Scan Photo/Document", then on the lower left side of the preview area click on the "Specify. ." button. Your Document Size is probably set at "Auto Detect (Multiple Documents)". Change this to the size document you are scanning and click "OK". Now you can preview and scan and not have segmented images.
Mar 03, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Re : CanoScan N640P/Lexmark Printing Problem.
There could be a setting in your scanner drivers to fix that. It would be under background settings.
The other thing you can do is preview the document first and select the area you want to scan. Then press the scan button again. That way the black background that isn't needed will not print.
Jul 29, 2008 | Canon CanoScan N640P Flatbed Scanner
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
1,574 people viewed this question
James Cagle
James Cagle
Jim Keysor
