Question about Dishwashers
My Frigidaire Dishwasher motor is not spinning rinse cycle
It all started few days back with a continuous humming sound even after the Dishwasher is off. That sound comes throughout the day. But the dishwasher was working okay that time.
Now when I start the dishwasher it takes the water in but does not start the rinse cycle. The motor never starts. The hot air/steam comes but the detergent is never used. The machine continues all the cyles till it goes off but nothing happens.
Thank you.
  • 1 more comment
  • mathviz Dec 25, 2007
    i don't have multi-meter at home. not sure i can get anything today. i have never open a dishwasher before, but let me see if i can find anything. thanks.
    not yet. unless i try it. it's christmas day here & tough to find store with multimeter.
    one thing - may be i overemphasized on motor issue. but the humming/buzzing noise (ALL DAY) is the start of all issues. rinse cycle does not start (after loading the water) is the main problem.
    may be the motor works, just some circuit issue. or water is not getting heated to the level that rinse cycle can start.
    i will check everything anyway. just was wondering if there is anything quick i can try.
  • 1,894 Answers
Am not sure.. just try this
Check with a multi-meter for 115/220V on motor's tags.
If you don't get this voltage measurement, your problem is not with the motor.
In case you have 115/220V on motor's tags, try first to replace its brushes (2 carbon contacts that transfer the curent to the motor's armature).
try this good luck
Posted on Dec 25, 2007
  • 2 more comments
  • dewan nafees ahmed Dec 25, 2007
    its very easy to open and check.. do it by yourself..
    i will suggest you to have a multimeter at home always.. branded ones are costly..
    but you can get local made ones for cheap rates..
    so my solution was not of any help for you?
    lols.. ya ya.. do it peacefully.. merry christmas.. here its over brother.. today was christmas here.. am from india
  • dewan nafees ahmed Dec 26, 2007
    may be one or more pads on the control panel got stuck. To fix it the console has to be replaced.
    but for safety you can call a safety
    but for safety u can call a technician.. bcz tis problem cant be solved witout having basics of dishwasher.. if u have opened safely before u can open it now and look into the control board.. else its not safe for you to open it..
    i will suggest you to call the technician.. bcz in this problem you dont take a risk of doin it by yourself..
    this forum talks about dishwashers many problems.. u may have a look at it too..
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My dishwasher starts humming in middle of cycle and wont go further the rinse cycle works fine
Hello & Welcome to FixYa
Either of these two things can cause this problem: first is the timer motor, if the sound is coming from the control then the timer needs replacement. If the humming comes from the bottom of the unit then it is the motor that needs replacement. When the motor won't work you usually hear humming sound and replacing the motor is recommended repair. Please get back to me if you have any other questions.
Mar 14, 2011 | Whirlpool 24 in. ADP5966 Free-standing...
Frigidaire Washer Model #WILL-1 - won't spin or pump out water
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Nov 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
My dishwasher is making a humming sound and does not rinse?
A humming sound can be a failing wash motor (that drives the water pump) or it can be as simple as a blockage in the the pump area beneath the lower spray arm, under the filter.
Remove the spray arm and the filter top (screws will need to be removed)
Use a flashlight and inspect all over the sump area for debris that is blocking/jamming the impeller area. Reasemble and test with a short cycle.
If the dishwasher continues to make the same humming, it is time to replace the wash pump.
Good Luck! Post back here if you would like more guidance.
Dec 08, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Front Load Washer Problem
Plug off the wall, open up the back to check your belt, might have come off. Place around motor pulley & turn the drum wheel to slip on the belt gently from either the right or left. If too loose you have to replace with new belt.
Rate if helped pl..................
Jan 04, 2008 | Washing Machines
Dishwashers Logo
626 people viewed this question
Top Dishwashers Experts
