Hi all, I have a MSD2456GEW Maytag side by side. Symptom: I have to slide the "freezer" control to "OFF" and then back past 1.5 to get the compressor to turn on. Runs about an hour or two, compressor cycles off, and then won't come back on again until "freezer" control is moved back to "OFF" and then up past 1.5. Cycle repeats ad nauseum. Where's the problem? Thanks in advance.
maytag msd2758dr not cooling correctly have to turn both sides up all the way. even with that not...
(More)
maytag msd2758dr not cooling correctly have to turn both sides up all the way. even with that not all that cool.
my maytag refrig/freezer side by side started leaking water from the inside and now does not make...
(More)
my maytag refrig/freezer side by side started leaking water from the inside and now does not make ice
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer...
(More)
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer some type of coil or element red hot like the element in the stove. And the water was running down from the back of my freezer, to the front of the fridge and leaking on the floor. It happens every few hours. What should I look to replace of repair? Model # is MSD2756GE
(More)
