Please help me with my daughters nano ipod she does'nt remember her password? i've tried the apple instuctions..
---If you do this you won't lose music"---
Well I went to my computer clicked my ipod and when the folders came up you go up top to "tools and folder options" and go to the tab that says "view" and click the one that says "show hidden folders." Then click "ipod control" then "Device" and delete the file that says "_lock" or something on that line. If you any questions email me at [email protected]
Try connecting it to itunes with ur usb cable, if it responds click on the ipod icon and click on reset to oraginal settings
I forgate my apple ipod screen luck code, how to open it ?
Hello All!
I had the same problem, my officemate came to me and asked formy help, her nephew tinkered on her ipod nano and set the passcode, and did not remember what it was.
the ipod nano can be unlocked when connected to the computer with itunes but, if you want to change the passcode to a new one it will ask for the old code which i dont have. even if you reset all the settings to factory default setting it will not reset.
this is a little hard for some of you to follow, but, to totally remove the unknown old code this is what i've done:
first, sync your music to your PC so that you have a backup of all your music. Second, make sure enable disk use is checked. third, format your IPOD. This sounds nut but this did the trick.
after doing this, check if you can set a new passcode to the screen lock, you should be able to do it. and please dont forget the new passcode. I hope this helps.
Oemor Yuson
Hello All!
Oemor Yuson
My ipod hav a pasword how 2 use it again in switch off passcode
i dont now it
My daughter has put a pin lock code on her ipod nano and has forgot what she put in, how do i get round this problem to enable to use again.
yhanks Brian
my ipod nano is locked and i didnt set a code.I dont know the password. HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
how do i reset my nano ipod password plz help!!!!!!!!
my ipod is asking to enter code. i do not remember my code as i've never set a code to it. i've tried all different numbers to see if will let me in but no joy. i cannot play my music. every thing is frozen. Can you advise how to get it working again.
thanks
LJ.
my little brother locked his ipod nano and forgot his passcode
ok i put music on my ipod and then i went to listen to it and i couldnt hear the music at all, even with the volume turned all the way up. so i went to settings to see wut was the matter and i saw volume limit and i went to it and it said i needed a password, i never set a password so i dont know what it is. i also tried differant headphones but they are all the same
please help
i put a code in my apple ipod and i forgot it plz help me how to get it back
I forgot my password for my 8GB ipod how do i fix that
I received it as a gift. The person who had it before doesn't remember the password.
