Question about GE 29196GE1 Corded Phone
Reset current time
I need to reset the time and am also trying to locate a users manual
I would like to reset the time, also. I cannot locate a users manual. The one I received with my phone is written in Spanish.
Posted on Mar 07, 2008
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
Current location for the HV-MX100 VHS VCR User Manual download
The current location for the downloadable User Manual is
The manual is at Sony's web site since Sony bought out Aiwa in 2002 (and discontinued the brand in 2006).
on May 06, 2009 | Aiwa HV-MX100 VHS VCR
Need to clear programmable settings
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the RESET button using a paper clip or a small pencil tip.
Nov 11, 2013 | Proselect PSTS21P52 Programmable 2 Stage...
How do I reset my garmin 885? I would like to reset to the original stage. Please help.
This procedure has been known to (but doesn't always) delete your favorites so back them up beforehand: From the nuvi drive, copy x:/Garmin/GPX/current.gpx to your backup location. After the hard reset, copy current.gpx back to the same folder on the nuvi but rename it temp.gpx (important). On the next power cycle, the favorites will be read from temp.gpx into the non-user accessible memory area on the nuvi where they are actually stored (current.gpx is only a shadowed backup of your favorites)
Power the unit off. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears. Press "yes" and the unit will reboot. Reset all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
Mar 11, 2011 | Garmin nuvi 885T GPS Receiver
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How do you change the time on the top of the display screen to the current time, How do you set the day to the current day and year
First, here are the links for your owners manual:
Time displays the current time based on the settings of the active profile.
Setting the Time Zone
The time and date information will be computed from information from the GPS satellites so there is
no requirement for you to input any time or date information. However, to make the time accurate
for your location you must select the correct time zone.
1. From the Map screen press MENU.
2. Select View.
3. Select Settings.
4. Scroll down and select Date & Time.
5. Select the Time Zone field.
Press button
Fundamentals 5
6. From the drop-down menu, select your current time zone. (Time zones are not changed
automatically when travelling. If you travel to an area with a different time zone, you will
need to change it here for accurate time information.)
7. Repeat the process for the Daylight Savings field.
8. Press ESC when done.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 07, 2010 | Magellan Triton 400 Handheld GPS Receiver
I cannot set another user or reset current user
This link allows you to ask questions and request a users manual....I hope this helps.
Dec 22, 2008 | Conair WW61, Weight Watcher Memory...
Check gps attenna
Try to reset your radio by romving the power completly on it. Restart it with your map dvd inside and wait for the update. When its updated , go in the gps screen. and start your car, turn around your block 3-4 time and sometime it relocate alone. ill try to check in my user manual, there is a way to tell the gps your exact location on the map , click it and make it your current posotion. Why it does that? Cause maybe your map dvd is not up to date , and your area isn't updated in your map dvd.
Jun 12, 2008 | Eclipse AVN5500 Car DVD Player
User's Manual
For the manual ask at
They will find it.
Oct 19, 2007 | Office Equipment & Supplies
Reset time & Users Manual
Press Feature
Dail #9
Enter hour And min via dial pad
Press recall to change am/pm
Press hold to change calendar settings
Or pree feature to exit
Press recall to select day of week
Dial # to move coursor to day of month
Press recall to change month
Dail # to move corsor to year field
enter # and press feature
Hope i've helped you I'm looking for a manual also
Oct 16, 2007 | Panasonic KX-T7730 Corded Phone
GE 29196GE1 Corded Phone Logo
143 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
