Question about Toshiba 65HX81 65" Rear Projection Television
Colors and Images
The colors appear to double imaged and the words are double imaged as well. It appears on the bottom 1/2 of the screen.
Watching TV today there were no problems. When turned on at night, the problem suddenly appeared.
  • 1 more comment
  • Anonymous Dec 28, 2007
    bottom half of picture has double picture. the colors are blue and yellow.
  • Anonymous Mar 06, 2008
    same problem
  • lindathomas1 Jul 30, 2008
    there is a red and green double imadge on menue script and a green spotted rainbow at bottom left to right of screen on a toshiba 65h81.please helllp im trying to fix myself thanks
  • 4,402 Answers
Sounds like loose connections on the convergance amps ic's
Posted on Dec 25, 2007
Youtube on my vizio 470i tv is off centered
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair, shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Colors bleeding, red tint around images
The liquid coolant between the guns and the lenses may be fogged, low, or both. If the red gun has fogged coolant, you'll see red fringing around objects. It can be drained and refilled with new coolant, but it's gotta be the right stuff. You may be able to get some from a junk set, as I have done with success. Shine a light into the front of each lens. If the liquid has gone bad, you'll be able to see it.
Dec 06, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Colors double
You appear to be having the same problem that I am having. I just found this solution and have ordered the parts, but not repaired yet. I think this link may help.
Jun 19, 2008 | Panasonic PT-56WX53 53" Rear Projection...
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Color alignment
It sounds like one of your convergence IC's has burned out and needs to be replaced. The defective IC will have to be replaced, the low-value resistors next to it checked and the convergence circuits realigned. If you do not have any experience working inside projection sets, allow a qualified tech to handle it for you.
Aug 31, 2007 | Hitachi 43FDX01B TV
Toshiba 65HX81 65" Rear Projection Television Logo
130 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
