Philips PM4S Remote Control
Problem for Philips PM4S Remote Control
Universal remote code
By lioness3085 on Dec 25, 2007
i need a code for a sylvana tv for my philips PM4S remote control
Same Problem
Jan 02, 2008
-   Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
-   tarra111111
Jan 02, 2008
-   I have the Philips Universal remote but need the code for a sony trinitron xvr-   Guest
Best Solution
posted on Feb 04, 2008
Very Helpful)
ThaMp3Doctor
Rank: Guru  Philips Expert
Rating: 86%, 4639 votes
The code for Sylvania is 0247 for a TV/DVD/VCR; for regular Sylvania TV's, there are several: 0807, 0002, 0502, 0115, 0520, 0919, 0324, 0402, 0408, 0109, 0715, 0717
The process for programming this remote with code is:
1. press and hold CODESEARCH until red indicator stays on
2. press and release desired mode button (TV,VCR, etc.) - the red light will blink and then stay lit
3. enter 4 digit code - after valid code entry, the red indicator turns off
4. with device on, press channel up - if it changes channel, you have succeeded
Comments:
Feb 04, 2008
- For a Sony, the codes are: 0414, 0902, 0801, 0708, 0639
Was this helpful?
Yes
No
Solution #2
posted on Jan 02, 2008
Very Helpful)
tarra111111
Rank: Apprentice
Rating: 93%, 50 votes
Was this helpful?
Yes
No
Solution #3
posted on Jan 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i am having trouble with this method:S i cant seem to chnge and cant go through the last step.. i have tried so many times. If there is any other solution do letme know thnks
confused
Popular Solutions for Philips PM4S Remote Control
Questions and Unsolved Problems for Philips PM4S Remote Control
Do you recommend Philips PM4S Remote Control?
Answer
Answer
need Sylvania Tv Code for digital remote
Answer
tv is stuck on video and remote will not work when i press input
Answer
i need to reprogram PHILIPS MAGNAVOX PM4S for GE t.v.
Answer
I have a philips unviversal remote for my tv that I used all last year I just moved and now it wont... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Remote... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
