Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer I need to change the gas value to LP and can't get the front panel off. How do you do it
  • Anonymous Jan 01, 2008
    have a ANSZ 215-82 Maytag gas Dryer Want to clean the lint but can't get the front off
  • 283 Answers
Take off the door then remove the screws on the other side (where the door would be attached if it were reversed) You can now swing the front panel down from the top.
Posted on Dec 29, 2007
Trying to mtake front panel off to convert from gas to lp
you need to remove the top cover by removing the screws out of the back,then remove the front control panel,then the front door panel and then the lower front access panel,all this needs to be removed to remove the gas line to the burner so you can take the burner tube out to change the gas orfice
Nov 18, 2010 | LG Dryers
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
How do I remove the front panel?
Hello, maytag makes it very hard to get to the lint.
You need to first take off the door, then the outer frame. The door has 4 philips screws and the frame should have 4 also. Good luck :)
Sep 15, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Matag Dryer to LP gas
Here is a link to a thorough explanation of what is involved in a conversioin and what to look for.
http://www.propane101.com/lpgasapplianceconversions.htm
May 23, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Jan 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I need access to gas valve in my Maytag mdg5500aww dryer
When I posted the question, I had not removed the front of the dryer. I thought the gas burner etc. had to be accessed from the back. As soon as I removed the front of the dryer I realized it was all up front and accessable. Conversion was straight forward from that point.
Jan 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Black residue inside gas dryer
r u on lp gas or nat gas if u r lp gas u need to convert the burner from nat gas to lp gas u need to call your gas co. to do the convertion
Dec 13, 2008 | Maytag Performa PAV2200
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Need to install LP converion kit How do I get to the inside of dryer
To convert a gas dryer to lpg. Undo door hinge screws, lift door and hinges, door should come off. opposite side of door opening remove 2 screws opposite form door hing side. Now the front panel will pull off front the top. Ease the top out and the bottom is just sat in two hooks and will lift out. Now your are in.
Nov 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MDG5500AW Gas Dryer Logo
81 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
