Question about Nintendo NES Console
Key Cannot find the key to get through the door....
  • Mary Cornelius
    Mary Cornelius Dec 25, 2007
    Super Mario 2.
  • Mary Cornelius
    in world 1.2 super mario 2..i can't figure how to jump that high to get on top of that structure OR to get a key to get through that door.
  • 3 Answers
What game are you playing
Posted on Dec 25, 2007
Key problem, I don't have a spare key and the key is not opening the door. The opening button on the key is very dead, please help me
First, the key"fob" has a battery inside. Any parts store should be able to help you replace it. Second, you should be able to insert the key into the door lock to manually unlock door. If car's battery is dead, most doors will let you insert the key and turn as far as it goes, Then operate the door handle and turn the key a bit more to unlock it.
Apr 06, 2016 | Cars & Trucks
I have a 1996 gmc suburban that i cannot unlock the driver's door. it was locked with key fob. i cannot unlock the door or open the door. the key will not unlock the door. help anyone?
if the key does not turn the lock spray it out with wd 40 run key in and out of lock few times.because everyone uses remotes to open their cars the waffers in the door locks get coroded and wont fall in proper place when key is inserted.give it good cleaning and see if it will unlock
Feb 03, 2013 | 1996 GMC Suburban
Mitsubishi colt 2005 driver door will not unlock with or without key
if the electric door lock actuator froze up this could cause the problem as it would not want to unlock either way it is inside the door panel hooked to the door latch
Jun 07, 2012 | 2005 Mitsubishi Colt 1.1
Need to replace the manual door locks , both doors
not locks ur key is probably worn down if both doors are not opening with key than problem is with key have a key cut and try locks [thats if u dont have a spare key to use ] if new key wont work than wil need to replace locks look in bone yard cheapest online moderate price dealer higher[or use vin number for new key can be pricey ]
Nov 23, 2011 | 1986 Ford F 250
Doors do not centrally lock with fob or key (they close but open straight away). Onlu option is lock drivers side with key and then lock the other 3 doors manuually. Ford Fiesta Mark 6 in the UK
hi
you need to try a couple of diffrent things with this problem
1- get in drivers seat close doors and lock by hand
2- then put key in ignition and turn key till dash lights come on (do not start)
3- while key in ignition unlock doors with fob ,
4 - then lock again with fob while key in ignition.
5- then remove key exit car try locking doors from out side this should reset all your door locks
Oct 25, 2010 | Ford Fiesta Cars & Trucks
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Jan 25, 2010 | 2004 Honda Accord
If i change my ignition after a break in do i need a new key for the doors and ignition too
If the door lock is undamaged then it's fine to use the old key in the door and the new key with the ignition - you then have 2 separate keys for ignition and door -
I dont quite understand the question... could you word it fidderently,
You said you "changed my ignition" - which parts of the ignition?
Jan 22, 2010 | 2000 Nissan Xterra
Side door lock on 2000 VW Beetle
the dealer gave you a ignition key, instead of valet key.
valet key should open the driver door and ignition. nothing else. if the key can't ope the door. try the trunk. if it open the trunk, the it is a wrong key.
Mar 25, 2009 | 2000 Volkswagen Beetle
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Dec 10, 2008 | 2003 Audi A6
Nintendo NES Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
