Question about Ovens
Refrig not working
Our refrigerator is only one month old and the freezer just stopped freezing today--everything is defrosted in it and the refrigerator is not as cold as it should be-----------------we have tried flipping the breaker, cleaning the coils, defrosting the condensor and no results!!! help==i have tons of food for christmas day in the refrig=thanks
  • 447 Answers
What brand is this?? Model#? Is the freezer fan working?? Is the compresor running?? Is there any frost on the back panel in the freezer??
Posted on Dec 25, 2007
How do i stop water ciming out of the freezer
check your condensation defrost run off line for blockage. may have to remove the back interior panel of the freezer to access the water catch pan. debris blocking the drain or the defrost line will cause overflow into fridge interior
Jul 03, 2014 | Frigidaire Ovens
Samsung SRS615DP Refrigerator
The temperature indicated is wrong because the thermostat sensor is faulty.
The faulty sensor (thermistor) send wrong info to display, and as it is also a thermic switch it turns off the compressor before it reaches temperature.
Insert model number here and get replacement part. On the website you also find info on replacement.
Jul 10, 2008 | Ovens
Refrigerator freezes up
Its a defrost problem... worth fixing timer,heater,or terminator often called defrost thermostat.
Sep 01, 2012 | Ovens
I own a Frigidaire Gallery refrigerator model # frs24xgcw ,the freezer sidehas stopped cooling and there is an occasional buzzing noise. Refrigerator side is working.The refrigerator is approximately 11...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Freezer not freezing on side by side fridge
Try turning the unit off and leaving the door open for half a day or more in case there is ice clogging something somewhere? If there is no cooling going on whatsoever and fan/s and compressor are running it sounds like a gas leak has devaloped or the compressor has stopped working correctly. If the compressor has stopped then possibly the controll circuitry to it has a problem.
Hope this might help
Dec 01, 2009 | Ovens
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
Water works but icemaker does not. the freezer barely cools
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 11, 2009 | Ovens
NO HEAT OVER 260
Hello red rum,
Yes, have seen this where the oven's thermostat needed to be replaced!
Bless You
Let me know how you are! Please remember to leave a rating before you sign off!
Huuum
Here is an interesting article i just read .
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 22, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Where do i find replacement glass tops for my hotpoint stove? How much do they run????? thanks for the info The glass top has burned, and i cannot remove to burns, can i replace the glass top? and how...
hello Chris700,
welcome.
1.What is the model #
2. How old is the range?
If the range is 6 years old or more it may not be worth spending to much money on it.
Bless you huuum
Here is an article I just read about this matter!
Repair or replace?
When a repair might be a wise choice.
When it pays to replace.
Thank You, HUUUM
Sep 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
46 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
