Question about Sony KP-44PX3 44" Rear Projection Television
Sony Projection TV stand-by light keeps flashing
  • clhsignature Feb 17, 2009
    My sony big screen timer stand by light keeps blinking no screen, but sound and all other remote functions work properly
  • dj chill Apr 28, 2009
    the standby light keeps coming on and the tv blinks out buthas sound only
  • 3,037 Answers
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
Posted on Feb 13, 2009
5 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: My SONY HD projection TV KDP-51WS550 (2005)
Hi, 5 times blink of standby light shows that TV needs White Balance adjustment. No need to dump it, adjustment is also not so difficult. Let me know if you want to give it a try to guide you.
Posted on Jun 15, 2009
  • 41 Answers
SOURCE: Sony Grand Wega 55 inch
6 blinks is an indication of a missing voltage. It's not the lamp or balast. It may be an indication of a thermal or heat trouble. These sets have thermal protection because of the heat created by the lamp. The thermal fuse may have opened. If this has happened you should have professional check it out. This set has 3 or 4 fans. These should be checked out or replaced. I suggest a Sony authorized repair. This is not a repair I would recomend for you to attempt. This set keeps a record of it's falures and the pro can check for any other trouble also.
Posted on Apr 24, 2009
SOURCE: projection tv wont turn on
i had same problem after house power switched off 3 times in same day disconnected power left overnight worked ok i will still take tv for a service .
red light was blinking 10 times
Posted on Feb 24, 2008
SOURCE: Problem for Sony KP-57WS520 57 in. Rear Projection
for me it blinks 9 times
Posted on Jan 26, 2010
My picture went out and the power/stand by light keeps flashing red. Tried turning on/off the tv with remote and manually and nothing changes.
When was the last time you changed the bulb?
The flashing codes on the power light tell us what the issue is, what are the lights doing and how are they flashing?
Mar 07, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Jan 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
32 in. Sony Trinitron stand by light keeps flashing
has a sony 41" REAR PROJECTION TV THE STAND BY LAMP IS BLINLING HAS RESET IT , NOTHING. HAS NO PICTURE NO SOUND
Jul 31, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Sony wega
Flashing standby light on a Sony TV means the its is doing its internal calibration / self check. If the light doesn't stop flashing the TV requires repair / replacement. This is exactly how mine died.
Jun 25, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Got a sony grand wega kf-42sx300u tv. the standby indicator on the tv flashes
Im afraid my friend the lamp needs replacing (model: XL-2100E), if you have a hunt on google you will be hit with the pain of the cost... like me :(
Aug 11, 2008 | Televison & Video
Flashing light
Video output IC on either the CR, CG or CB pcb boards is most likely the problem or the A board is defective. I would try the video output on the CR, CG and CB boards first.
Jul 16, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-44PX3 44" Rear Projection Television Logo
5,270 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
