Jenn-Air model #sve47600b. Today put new display control panel in. Didn't fix the problem. The display now works, but the oven light and fan will not stop running. Also the touchpad doesn't work. If it isn't the display panel. What can it be?
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
I have a Jenn Air electric range thats about 12 years old, and the digital readout on the control...
(More)
I have a Jenn Air electric range thats about 12 years old, and the digital readout on the control panel no longer lights up, but all the bottons still work fine. The replacement part is $170, is it worth replacing on a 12 year old unit, and if so, is it hard to do?
Was having problems getting the burners on my old Jenn Air electric range Model C360 to work...
(More)
Was having problems getting the burners on my old Jenn Air electric range Model C360 to work consistently. Changed the terminal blocks and get heat each time they are switched on, but one switch causes both burners to turn on. Replaced the switch and the same thing happens. Am stumped. Can anyone suggest a next step in troubleshooting?
The installation manual says to cut a 6-1/4" diameter in the floor, then mount the fan with 4...
(More)
The installation manual says to cut a 6-1/4" diameter in the floor, then mount the fan with 4 screws, but the two screws in the front just drop into the 6-1/4" hole.
