Back to:
Tags:
Sony MDS-JE520 Mini Disc Player
Sony mds-je520
By Chandler - usenet poster
Has anyone had any problems with the Sony MDS-JE520?  I know there were
a lot of problems with the 510, but did sony fix them with the 520?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Ross
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi
Actually, I've had no problems with either my MDS JE520 or my MZR50
portable. Both great units, highly recommended. However, Don't try playing
with the buttons on the JE520, you'll expereince some 'weird' modes. I was
messing around, pressing combinations of buttons while it was off to see if
it did anything. I got a shop demo thing which I couldn't get rid off (Its
gone now though!?) and also, I inserted a disc after a werid combi and it
said Aging on the screen. Agghh! Panic. It erased my TOC or something, when
I wasn't aware of TOC cloning so I lost the recording. Don't let it put you
off though, I was just curious what would happen and those combinations
wouldn't happen in normal operation of the unit!
Laz
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sony mds-je520:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Perkins
Rating: 0%, 0 votes
Well ! It??s strange that they are the only ones that daires to leave a 2
tear waranty !
Thank You!
Solution #3
Not Rated (0)
Cornish
Rating: 0%, 0 votes
The only problem I have is that sometimes the fader, which I use
whenever I record from LP's, counts down a different time than I
programmed, and it doesn't pause. This happens about 1 in 20 fades.
Scott
Thank You!
Solution #4
Not Rated (0)
Charlie
Rating: 0%, 0 votes
JoeDoe <joe @mediaone.net> wrote in <36807940.3D75C @mediaone.net>:
I've had a 520 since September 10, and it shows none of the bugs that have
plagued my 510s (only one of which I still own, as the other was exchanged
under a lemon clause; that's how I got the 520).
The 520 so far has evinced only one tiny problem: sometimes when I delete a
track and the 520 exits deletion by trying to play the track that follows,
and the track after the deletion is very short (less than one second every
time this has happened so far), the unit sticks at the beginning of the short
track and just hangs there.  Pressing PAUSE gets it out of catatonia into
pause and pressing PAUSE again (or PLAY) resumes normal play.
Contrarily, I often divide tracks very near their ends, another process that
leaves the unit about to try to play a very short track, and this bug never
strikes on those occasions, only after deletions.
This does NOT happen in regular playback, only after deletions, and only when
the next track is very short, and even then not always.  Since it never
occurs when the unit is unattended, it is no problem to press PAUSE twice to
get out of it.
The reply address is valid but I'll see mail to dattier at mcs dot net sooner.
Thank You!
Solution #5
Not Rated (0)
Horner
Rating: 0%, 0 votes
I don't know nothing about Sonys supposed bad quality, maybe it's true but I
can only speak for myself, I own an old sony discman, (works like charm even
though it looks kinda scratched 'cause of tough use ...) a mds-je520 MD deck
(works perfectly so far, no self turn on bug or anything like that, though I
haven't had it for that long time..), a mz-r50 (which has caused me some
problems, though the first wasn't the units fault, there was some piece of
plastic jammed inside the unit.. the other time there was a broken optical
input but the warranty coverd that so what the hell.. didn't cost me a
buck), and finally the sony mz-e55 ( a wonderful little unit, seems to me as
it's even less sensitive than the sturdy mz-r50, which has survived being
dropped to the floor w/o any protection more than one time, because the e55
doesn't have any recording capabilitys there's less that can brake I
figure..
Thank You!
Solution #6
Not Rated (0)
Green1
Rating: 0%, 0 votes
Considering we're talking about Sony, probably not. And even if the
problem WAS fixed, Sony's reputation for poor quality should indicate that
something else WILL go wrong. Too bad all the Japanese manufacturers are
hesitiant to put their decks in the American stores....when I bought my
unit, Sony was the only choice I had :-/  And of course, I have the faulty
510.
Joe
Thank You!
Solution #7
Not Rated (0)
Joey2
Rating: 0%, 0 votes
I have a 510 and it works fine. What are the known problems with the unit?
Thank You!
Can you Help with these Mini Disc Players problems?
Mini Disc Players
our new hm3817dt volume plays at almost full blast when...
Mini Disc Players
I just bought the Durabrand HM3817DT system from WalMart....
Mini Disc Players
mini hifi sysrem philips
Mini Disc Players
when i load a disc into the machine the message...
Mini Disc Players
how can i get my jvc mini disc to play on my computer......
Loading problems.
Repair Service
Find Mini Disc Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
