Question about Cuisinart DGB-600 Coffee Maker
Will not turn on
There is power: I have been able to program time. However, the machine just beeps and when I press power on, it lights up while I am pressing it but will not power on. I have unplugged it but when I plug it up and press on/off, it just starts beeping again.
  • Anonymous Dec 30, 2007
    same problem
I had the same problem. i had left a part out, the clear top to the beans. Once I put it in, it worked. i think this is a safety featr=ure
Posted on Jan 27, 2008
How do I reset my Fisher Washing machine size?
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE UP then press POWER. EcoSmart will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
 Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
 Press POWER to confirm the setting and also exit this mode.
Apr 15, 2015 | Fisher Paykel EcoSmart GWL15
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
Restart off
4.4 Restart Feature
If a fault occurs in the machine, the diagnostic system will detect it. However, instead of displaying
a fault code immediately, the machine will try to restart. If the fault was only of temporary nature,
the machine will restart and finish the cycle. If there is a continuous fault the machine will try to
restart a number of times.
This process could take up to 8 minutes depending on the type of fault. After this, if the machine
still cannot restart, the fault code is displayed and the machine will beep continuously. The number
of retries will depend on the fault that it has detected, however the maximum number or retries for
any one fault is 32 times.
The restart feature is turned on when a machine leaves the factory. For servicing we strongly
recommend that this feature be disabled.
To turn the restart feature on follow the procedures below:
1. Enter diagnostic mode (Refer to Section 4).
2. Press WATER LEVEL DOWN so that the low water level LED is lit.
3. Press POWER to turn the display off (the 5 leftmost wash progress LEDs will be flashing).
4. Press POWER to turn the machine on.
5. The machine can now be tested on any cycle.
To turn the restart feature off, either repeat the steps above or switch off the power to the machine.
The restart feature can be permanently programmed in to the machine's memory. When in
diagnostic mode press and hold ADVANCE down at the same time as pressing WATER LEVEL
DOWN. A long beep will acknowledge the setting has been retained in EEPROM. Press POWER
to retain selection as with size switching. To remove from the permanent memory, repeat the
above procedure.
Note: This feature is designed as a service aid only and should be left on in the customer's
home. To return to normal operation, and to reset the restart feature to the factory setting,
switch the machine off at the wall or disconnect from the mains supply.
4.5 Recycle Feature
The recycle feature, when enabled, will cause the machine to continuously repeat the cycle that
has been selected. At the completion of the spin cycle the machine will power off briefly then
power back up again and will start the cycle programmed.
This feature would be useful to help identify an intermittent problem, and would be best used if the
machine had been taken back to a workshop for service.
To turn the recycle feature on follow the procedures below:
2. Press WATER LEVEL UP so that the Medium water level LED is lit.
3. Press POWER to turn the display off (the 3 rightmost wash progress LEDs will be flashing).
Note: This feature is designed as a service aid only and should be OFF in the customer's
home. To return to normal operation, and to return the recycle feature to the factory
setting, switch the machine off at the wall or disconnect from the mains supply.
Feb 12, 2012 | Fisher and Paykel Fisher & Paykel Washer
Reset tire monitor on 2009 escalade
Hopefully you still have you manual. I will tell you how to reset the HHR, I found it in my manual. Turn the key to on, press lock and unlock at the same time on your key fob. The horn will beep twice telling you that you are in program mode. The left front turn signal light will come on, press the valve core letting air out of the left front tire. The horn will beep when left front is programmed. Then the right front turn signal will come on, let air out till horn beeps. Then right rear, same procedure then left rear same procedure. When that is done horn will beep twice again saying tire program is complete. Turn key off, make sure you air all tires back up.
Jan 03, 2012 | Cars & Trucks
The additional ingrediets beeper is not beeping. My machine is relatively new.
If you have your manual there is another way to handle the add-in beep. Find the page that shows the lengths of each program. The programs that have the add-in beep usually show the time that it occurs. So if you watch your timer you'll know when its close.
Sometimes I just set the timer on my oven because it is much louder than the bread machine alert and it doesn't stop until I turn it off, unlike the bread machine which shuts off after a few beeps.
Just synchronize your oven timer with the timer on the bread machine.
Example:
with my machine my manual says that when the timer says 2:35 the beep will sound with the sweet bread program for a 1.5 lb. loaf light crust. I just take the subtract that from the time of the total program and set my oven timer for that time. When I hear the oven timer go I add my fruits, nuts, etc.
Dec 20, 2010 | Black & Decker Bread Machine
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Diplomat adp 8242 beeps twice one flashing light not working. turn off leave for hours then might work.
    Turn off plack power button, turn back on, then press cycle selection button 4 times very quickly. flashing lights should change, shut machine and it should fire up and work...... it worked for me. May have to try it several times as getting the 4 button press timed right can be a bit tricky.
    Jul 13, 2009 | Dishwashers
    How do I pre brew
    I got one of these for xmas, and I was able to program the pre-brew option.
    First, turn off the machine.
    On the front of the machine, there is series of 5 buttons. (From left to right, they are: Small Coffee, Large Coffee, Pre-ground Coffee, Hot water and Descaling.)
    While holding down the 1st (Small coffee) and 4th (Hot water) buttons, turn on the power.
    Wait 3-5 seconds before releasing these two buttons. You machine is now ready for programming.
    Below the 5 buttons are 4 small lights. If the second light from the left is red, the machine is already programmed to pre-brew. If the light is not red, do the following:
    Press the Coffee button (2nd button from the left) once and the second light from the left should glow red. This turns on pre-brewing. (Pressing the Coffee button again will turn off both the light and the pre-brew option.)
    Now turn off the power for at least 5 seconds. The next time you turn the machine on, it should pre-brew the coffee.
    The process worked great for me the first time, but when I wanted to program the machine to not pre-brew, I had to go through this process a couple of times. Not sure why, though. :-)
    Kathy
    Jan 13, 2009 | Saeco Incanto Classic Espresso Machine
    Dishlex global 300
    try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
    Feb 04, 2008 | Dishwashers
    Cuisinart DGB-600 Coffee Maker Logo
    113 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    880runner
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
