Your owners manual will tell you which fuse and its location on the fuse box panel, which is located behind the pull down tray, to the left of your steering column.
Hi, either the lighter is bad, or you have blown the fuse on it. Locate the fuse panel, and change the fuse. If you have the owners manual, it will tell you where it is located. Normally, under the dash left side of driver. Shastalaker7
You have a blown fuse which is possible caused by the cigar lighter,Is anything plugged in to the socket,if so remove it and the replace the fuse[check the owners manual for the location]
The schematic doesn't give me an indication of the fuse label, but it does tell me that you're looking for fuse #18 (15A) in the dash fuse box. According to the fuse box diagram I have, that's the ninth fuse from the left in the center row.
Hello there
first check the obvious the fuse your owners manual will be able to tell you the exact location and type of fuse.
if this is good you are going to be looking at getting a new lighter walmart or autozone has these fairly cheep ok best regards mike
it is possible that the remaining piece of your charger has shorted it out and blown the fuse. If you look through your owners manual it will tell you the location of the fuse panel and which fuse is for the cig lighter and radio........sorry im not familiar with these locations on your vehicle or i would tell you exactly where it is hope this helps!
