Back to:
Tags:
OnStream ADR2 60ide ADR Tape Drive
Problems installing Tapestreamer ONSTREAM...
By Cornish - usenet poster
I bought a ONSTREAM ARD2.60IDE, which i try to install on my Netware 5.0
sp6 -server. This tapestreamer is an IDE-based device. All the other
devices are scsi-devices that perform well.
When I try to load drivers for the device, the device won't work.
There were no drviers delivered with the tapestreamer.
It appears standard drivers from Novell should work.
The only problem is : I have no documentation about it and it seems
ONSTREAM has gone broke. I can't get any support.
Thanks.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
kcw573
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I'm not aware that any IDE tape device works with the Novell-supplied
drivers, not sure what makes you say otherwise. But you might try in the
netware5x.server-backup forum for more help.
 Andrew C Taubman
 Novell Support Connection Volunteer SysOp
 http://support.novell.com/foru ms
 (Sorry, support is not provided via e-mail)
 OneNet is better than nothing.NET
 Opinions expressed in the above text are not
 necessarily those of Novell Inc.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problems installing Tapestreamer ONSTREAM ADR2.60IDE.:
I don't want to Accept this solution
Can you Help with these Tape Drives problems?
Tape Drives
Hi , i was connected my tandberg T40 tape library to my...
Tape Drives
We just upgraded our tape drives from AIT3 to AIT5. I...
Tape Drives
Inserted tapes into the tape library and put it back...
Tape Drives
My External LTO drive senses the tape is write protected...
Tape Drives
hi, I have a bright scanner s/n 52d313023071. I lost the...
Loading problems.
Repair Service
Find Tape Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
