Question about Brother MFC-5440CN All-In-One InkJet Printer
Coupon printer problem - can't unselect Keep Printed Documents
CAN'T PRINT COUPONS IT SAYS TO UNCHECK (KEEP PRINTED DOCUMENTS) BUT WHEN YOU UNCHECK THIS AND OK IT AND TRY TO PRINT AGIN ITS CHECKED AGIN? CAN YOU HELP.
This is happening on a Brother HL-1440
Having same problem with Brother MFC-5440CN, no matter how many times you unselect, check mark returns. Any help would be appreciated.
  • 2 more comments
  • Steelcity-jd Dec 26, 2007
    I was able to solve the problem with the MFC-5440CN by selecting control panel, printers, properties, advanced. Under advanced select "Print directly to printer" this disabled the keep printed documents file and I was then able to print coupons. Hope this works for the others.
  • Jazzy20743 Jun 05, 2008
    Brother MFC 5840cn
    Coupon printer problem. I can't unselect "Keep printed documents".
    Coupon printer says uncheck "keep printed documents". Each time I uncheck it, click okay and to print the coupon, I get the error message, "uncheck keep printed documents". The unchecked check mark cannot be unchecked.
  • Anonymous Oct 19, 2008
    awesome, it worked!
  • Anonymous Nov 04, 2008
    I had the same issue and this fixed it right off! thanks!!
Informes de fax enviados
Posted on Feb 09, 2008
I don't know how to disable "keep printed documents". I have an Artisan 800 series printer.
Hi Michelle,
Follow the steps below and you will be able to fix the issue.
Click on START button
Click on Control Panel ( or Settings for windows XP )
Click and open Printers and Faxes ( or Printer folder icon )
Highlight the Printer icon and Right click on it
Left Click on Printer properties
Click on Advanced TAB on top and look for "Keep Printed Documents"
If there is a Check mark, you can Uncheck it.
If there is no check mark on it, Check mark it.
Click Apply/OK and Close the window and try to print.
If this does not resolve the issue, Try the step below
1. Open Printers and Faxes.
2. Right mouse click on the Epson printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Regards,
Sean
Sep 14, 2012 | Epson Artisan 800 Series
How can I turn off the Keep Printed Documents selection?
First right click the printer icon in the SysTray (by the time usually) clear all documents.
Then pull the power cord and leave it unplugged for a few minutes, When you plug it back in the the memory in the printer should be clear.
Dec 10, 2009 | Brother MFC-3240C All-In-One InkJet...
I am unable to print documents from computer. I
There is a switch on the right and the cover press it when it closes.Put a small paper to help the cover small plastic stick on the right to keep the switch pressed. Then you will print normally
Oct 26, 2009 | HP PhotoSmart 7960 InkJet Printer
Will not Print online Coupos
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
2. Right mouse click on the Brother printer and left click Properties.
Documents.
Try printing the coupons again.
Aug 20, 2008 | Brother HL 5140 Laser Printer
The "keep printed documents" stays checked after i uncheck it!
Had the same thing happen. Go to properties, then advanced and check "print directly to printer". You'll be able to print your coupons. Make sure you go back to your previous settings when not printing coupons.
May 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Deletes and reinstall print drivers, does'nt sound like a printer problem, more software issue, driver reinstall is my best bet
What are you printing from? ie program is?, and can you print windows test page OK?
Dec 19, 2007 | Brother HL 5140 Laser Printer
If you have a Brother printer please change the following:
Start -> Control Panel -> Printers and Faxes -> Right click on your selected printer and select "properties"
Go to Advanced tab -> Print Processor
Change the settings from "BRMFC" print to "WinPrint" and set default to "raw" and Click Apply
Now go back to uncheck "Keep Printed Documents" and attempt to print the coupon.
I am a big fan of coupons.com, their tech support guy sent me these instructions. Good Luck!!
Nov 20, 2007 | Brother MFC 420CN All-In-One InkJet...
I in the Properties=>Advanced tap, select the option "Print directly to the printer". This will resolve your issue.
Oct 31, 2007 | Brother DCP-110C All-In-One InkJet Printer
Printing problem
Go to MFC5840CN Printer Properties -> Advanced 2. Click on Print processor 3. Select Winprint, then click OK 4. Uncheck 'Keep printed documents', then click OK 5. Go back to Printer Properties -> Advanced again to make sure the option is unchecked.
Sep 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
1,542 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
