Question about Motorola Mobility SLVR L7 Cellular Phone
Camera how do you take a picture
    Brigadier General:
  • 7,752 Answers
Press the menu button in the middle of the keypad then scroll to camera.
Posted on Feb 08, 2008
Pictures download but aren't on card
There are several possible causes for this.
1a) The pictures are in a folder unknown to the camera. This could be due to the folder name, or its position in the folder structure.
1b) The pictures have filenames that do not correspond to the camera's naming scheme.
2a) The pictures were taken by a different camera. Many cameras will not display pictures that were taken by a different camera.
2b) The pictures have been edited on a computer. Many cameras will not display altered pictures.
Unless you have very strong reasons for keeping some pictures on the card, you should have the camera format the card after you download the pictures to a computer. Formatting wipes out all information on the card, preparing it afresh for further use. Failure to format the card periodically can lead to future problems.
If you need to keep some pictures on the card, format the card in the camera, then use a card reader to put the pictures back onto the card.
Aug 09, 2012 | Transcend Sd Hc Sdhc Class 10 16gb 16g 16...
Viewing pictures on camera
When you rotated pictures you changed picture size and definition, that is the reason why camera does not display them again.
If you check file size, you will see that rotated pictures are smaller than regular ones.
There is no way to get picture to original definition once you reduce it, however if you use a program like Photoshop you can check size and definition on original pictures, and re-rotate and resize rotated pictures to send them back to the camera, quality will be poorer than originals. Attributes to check are length and width (preferably in pixels) and definition, then you save pictures as best quality.
Aug 09, 2008 | Panasonic Lumix DMC-FX12 Digital Camera
Tip
Transfer photos from Camera to PC
<span><span><i><b>Hello and welcome to FixYa!</b></i><br /> <br />To transfer your photos from your</span><span> Digital Camera</span><span><span> to PC, Follow the given steps:</span><br /> <span style="font-weight: bold;">1.</span>First connect your digital camera to your computer.<br />You can do this in two different ways:<br /> <br /></span></span> <ul> <li><span><span> <b>Use a USB cable:</b>Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.</span></span></li></ul> <ul> <li><span><span> <b>Through memory card:</b>A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk.</span></span></li></ul><span><span> Now connect USB cabe or Memory card Reader to the port of the computer<br /> <span style="font-weight: bold;">2</span>.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, your computer will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click <b>Microsoft Scanner and Camera Wizard</b>, and then click <b>OK<br /><br /><img src="angel_bird_1.gif" /><br /><br /></b></span></span><span><span>If you are using a memory card reader, click <b>Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard</b>, and then click <b>OK</b>.<br /><br /><img src="angel_bird_2.gif" /><br /><br /></span></span><span><span><span style="font-weight: bold;">3</span>.When the Scanner and Camera Wizard appears, click <b>Next</b>.<br /> <span style="font-weight: bold;">4.</span>All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the <b>Rotate clockwise </b>or <b>Rotate counterclockwise </b>button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click <b>Next</b>.</span></span><br /><img src="angel_bird_3.gif" /><br /><br /><span><span><span style="font-weight: bold;">5.</span>On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click <b>Browse</b>, and select a folder in which to save your pictures.<br /> <span style="font-weight: bold;">6</span>.If you want to erase the images from your camera's memory card to make space for new ones, select the <b>Delete pictures from my device after copying them </b>check box, and then click <b>Next</b>. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card.<br /><br /><img src="angel_bird_4.gif" /><br /><br /><br /></span></span><span><span><span style="font-weight: bold;">7.</span>On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click <b>Nothing</b>, and then click <b>Next</b>.<br /> <span style="font-weight: bold;">8.</span>On the final page of the wizard, click <b>Finish</b>. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera.<br /> Your photos are now stored on your PC, ready for whatever you want to do with them, and <span style="font-style: italic;">your camera is ready to take more pictures.</span></span></span><br /><br /><span>Thank you for Using FixYa!</span><br /><span><span><br /></span></span>
on Apr 28, 2011 | Cameras
Iam unable to view the pictures I took with my former Easyshare. It says unreconized-file format. Is there a way I can view the pictures taken with my old camera?
Many cameras will not display pictures that were taken with a different type of camera. You should still be able to view those pictures on the original camera, a computer, or a digital photo frame.
If I may make a gentle suggestion, use your camera to take pictures. To display them, use something better suited for the task.
Jun 12, 2012 | Kodak Easyshare Max Camera Z990 Digital...
I snapped so many pictures with this camera, but when i wanted to view the pictures from the camera, its all showing file errors. pls what do i do
The problem maybe with how the camera is saving the pictures. I recommend that you save the pictures to the camera card and put it in a card reader or plug the camera directly to a computer and use that to view the pictures. If the pictures are still the same then there is a problem with the camera.
Regards.
Dec 12, 2010 | Samsung DualView TL220 Digital Camera
I want to download my photo's from camera to hp laptop
After you take pictures with your digital camera, you'll want to copy the pictures from your camera to your computer so you can print them, share them with others, and back them up for safe keeping. Once your pictures are on your computer, you can erase them from your camera, freeing up memory so you can take more pictures. You can also view your pictures on a larger screen and decide which ones are worth keeping. Some digital cameras come with software that helps you copy pictures from your camera to your computer. You can use this software, but you don't have to. Windows XP can copy pictures to your computer without requiring additional software. Here's how to copy your pictures using Windows XP: 1. First connect your digital camera to your computer. You can do this in two different ways: ?Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. ?Use a memory card and memory card reader. A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Tip: It's usually faster to use a memory card reader to copy your pictures than to connect your camera to your computer with a cable. 2. Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK. If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK. 3. When the Scanner and Camera Wizard appears, click Next. 4. All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next. 5. On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures. Tip: Create a new folder for each group of pictures you download. 6. If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card. 7. On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next. 8. On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera. Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures. As with any important files, it's a good idea to make backup copies of your photos, in case anything happens to your computer
Apr 08, 2010 | HP Photosmart M547 Digital Camera
Can't put pictures on the camera
you can do something
1.take picture in camera .
2.copy the of the picture .
3.go to the picture you want to put in camera .
4.past the name on the picture.
5.change the dimensions of the picture to 3264x2448 or 2448x3264
6.then put the picture in camera (sd card)
its work with me
Jul 26, 2009 | Fuji FinePix J10 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Picture has horizontal areas or differant colors and distortions
It sounds like the processor for the camera is messing up the picture. I suggest that you take the camera in to a Wolf Camera or any other camera oriented store
Aug 28, 2007 | Vivitar ViviCam 5340s Digital Camera
I can't take a picture with the camera. What should I do?
The camera may be full. Check the picture counter on the display panel. If the camera displays "00" the camera is full, erase some pictures or transfer the pictures to your computer and then erase them. Another option would be to install a SmartMedia card to store more pictures. Also, when the camera is connected to your computer you can't use any of the controls on the camera itself. See Chapter 7 of the user's guide for instructions on taking pictures from you computer.
Sep 13, 2005 | Epson PhotoPC 550 Digital Camera
Motorola Mobility SLVR L7 Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
