Question about Kodak EASYSHARE 5100 All-In-One Printer
Photo copy problem
I'm trying to print pictures but my printer won't respond when I press the photo button it still stays on the copy botton
  • camster Jan 11, 2008
    my photo light, scanner light and and transfer lights do not work???
    pictures take forever to start printing
  • 30 Answers
You need to connect a photo source to the printer to select "photo" mode. A usb drive or a pictbridge camera would be suitable candidates.
Posted on Feb 08, 2008
Getting error message, "refer to
Try to check the Print Cartridges if they still have ink in them. or try to do a Semi-Full Reset. combo would be: - "print photo" + "red eye removal" buttons pressed together - printer will not ask you to enter the combo - release the buttons you pressed then - press "red eye", "print photo", "red eye" in sequence - scroll down or right until you find resets menu - press ok - scroll down or right until you find semi-full reset - press ok
- your printer should turn off, wait for 3 minutes before turning the printer back on
Mar 23, 2011 | HP Photosmart C5280 Printer
Epson Stylus Photo R200 prints red lines under all the print (not the whole page, just the printed part). This includes pictures.
maybe its out of ink.
if still full then
perform this instructions.
click settings, printer and faxes, then right click of the printer device you are using. then click properties.
click the maintenance botton on the upper right then click cleaning botton..
repeat until the printing goes back to normal.
Sep 25, 2010 | Epson Stylus Photo R200 InkJet Printer
Printer does not respond to "Copy" command
Press and hold the Setup button, and then press Options (or Copy Options ).
It will bypass the alignment.
Apr 09, 2010 | HP PSC 2175 All-In-One InkJet Printer
Printer is printing, but nothing shows up on paper.
Try to do test print directly from the printer
1. Press at the sane time for 10 sec, the photo and copy button.
2. Clean the printhead simple press the menu button > selet clean printhead > select basic/deep clean
3. If it print a test page using the scanner glass. Place a doc./picture on the glass and copy it
4. If it failed call 1 800 421 6699 for assistance replacing the printhead
Nov 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
It will not print the black ink
Have you clean the printhead and reseating the ink cartridges?
heres the you need to do
-Reseat both ink cartridges
-Calibrate the printhead (Press menu button and look for calibrate printer to do it)
-Clean printhead (press menu then look for clean printhead choose deepclean)
-Press and hold Photo and copy botton at the same time to print your DEMO PAGE!
-If the black is absent it means the nozzles of the printhead is clogged you need to call kodak for printhead replacement Toll Free 1 800 421 6699. GudlucK
Nov 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lines through pictures
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 11, 2009 | Kodak ESP 5 Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot cancel copy process keeps on printing even when I press cancel button prints the same document over and over I want to print a picture from my computer can I download a picture from my camera...
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 18, 2008 | HP Office Equipment & Supplies
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Kodak EASYSHARE 5100 All-In-One Printer Logo
46 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
