Question about Apple iBook Mac Notebook
Always freeze my ibook G4 has recently frozen everytime I use it. I use firefox and it got frozen. I use Itune, it got frozen. Did reboot and it still got frozen. I did the fsck thing only to find out that he harddrive is a OK. Consulted with the geeky tech mac support but couldn't find solution. Please help?
  • nicole1225 Mar 03, 2008
    The computer freezes no matter what application or software I am using. I can be able to access it for anywhere from 30 seconds to 30 minutes then it completely freezes up. It has been re-started several times and nothing has fixed it.
  • 4 Answers
My iBook freezes everytime also. Used to boot only to blue screen, removed Aircard and RAM module, now almost always boots to OSX, but locks up after a few minutes of use. Try this... boot and hold down Command+S keys, to boot into command line mode. Leave it for a while. If it eventually crashes in command line mode, you can rule out OS problems, as it will probably be hardware. That is what mine does. It does run much longer in command line mode, but will crash eventually. I hate my iBook.
Posted on Feb 10, 2008
  • 667 Answers
Firefox will use a lot of disk space over time for temporary use. You might try starting up and run the Disk Utilities program to repair disk permissions.
Posted on Dec 25, 2007
How do I reconnect to the internet, I restored my iBook G4 to factory settings and although I am connected via Airport am receiving an error message that no ports are open . Everytime I try to open T
The pointer jumping on the screen sounds like you may have picked up a virus. While rare, there are mac viruses. I would try to save all my data documents and any other valuable personal files or lists, then do a clean reinstall of the operating system. Then load our documents back in.
You could try to scan for a virus with a mac virus program, but not many are available for a G4 Power PC (PPC) machine.
May 10, 2014 | Apple iBook G4 Mac Notebook
Why does my Apple iBook G4 display ''you need to restart your computer''?
Have you added memory to the machine?
If so, is the memory to the right specification?
Mar 08, 2013 | Computers & Internet
I have recently purchased a mac ibook G4 and unfortunatly it fell of the couch.Since then i have been having problems with Safari(internet browser).Safari and the cpu will freeze as well.Everything else...
Not sure what is going on with safari but what I would suggest is reseating your RAM on your ibook, it may have come loose. to do this have a look at http://www.youtube.com/watch?v=U-3406L3yL0 it is fairly easy to do. You will at the same time as reseating the RAM you will have to remove the airport card and replace it in the same slot, this may sort the safari problem. Have you tried using another browser such as firefox. Hope this helps in some way.
Feb 03, 2011 | Apple iBook G4 Mac Notebook
I recently got a ibook g4 from someone that said the os kept freezing at the startup. I tried reinstalling from the install disk that came with it. It get to the end of the first disk then says there was...
Your hard drive is failing or has some bad sectors.You can get HDD Regenerator software and run it and it most of the time will regenerate the bad sectors causing problems such as yours.If that doesn't work then your hard drive is failing.Also the install disc may be corrupt/scratched causing the error as well.The OS freezing at startup also indicates the hard drive is bad.
Jan 26, 2011 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Frozen
Mostly it will be the hard disk. Freezing is caused by many things in your machine.
Tech from
http://www.computerstar.ca/
Apr 21, 2010 | Apple iBook G4 Mac Notebook
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Mar 18, 2009 | Apple iBook G4 Mac Notebook
Ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
Feb 16, 2009 | Apple iBook G4 Mac Notebook
Ibook g4 12" 800mghz freezes alot, especially when bairly moved
Hi Robert
Try a reset of the PMU, instructions here:
http://support.apple.com/kb/HT1431?viewlocale=en_US
All the best
Sean
PiDigital
Dec 30, 2008 | Apple iBook G4 Mac Notebook
Ibook g4 freez
Freezing is a HD problem. Do you hear clicking sometimes? Sometimes on boot up is there a foler with a questionmark in it? I would get your hard drive looked at, this is the reason disc utility fails. Your hard drive has a hiccup.
Jun 19, 2008 | Apple iBook G4 Mac Notebook
No luck
Probably the dvd drive is damaged (boot the computer with a bootable cd and see if it works, if not, change the drive), or it might have weak connection in it's slot, remove it and reinsert it in the laptop, see if it works.
Jan 16, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iBook Mac Notebook Logo
336 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
