1994 Suzuki Sidekick Logo
Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine sputters under load. engine surges then drags---sometimes it runs normally then for no reason problems arises again.
  • mike loshbough
    mike loshbough May 11, 2010
    have your injectors cleaned and your plug wires check.
Boyet Soriano
Level 2:
Sergeant:
  • Expert 293 Answers
  • Posted on Oct 09, 2009
Boyet Soriano
Expert
Level 2:
Sergeant:
Answers
293
Questions
Helped
123451
Points
758
Have your EGR valve checked. Defective EGR valve will cause all the symptoms youare experiencing
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 10, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
568
Points
It it's a throttle body...I have had the same issue and know the fix...email me at [email protected]
1helpful
Why my 2003 3.3L Voyager sputters when aircon is turned on?
I guess I should start with the obvious - the engine is under extra load with the ac running. So any minor problem with the ignition or fuel system will be magnified.
Could be weak spark plugs or wires, anything that would cause a miss.
There could be a problem with the amount of drag coming from the ac compressor too.
2000 nissan xterra was barley running yesterday missing and sputtering took forever to get up to speed and this morning it is running fine what could this be
Sometimes the computer will have an intermittant glitch. Wait to see if problem reoccurs and monitor it based on engine start-up/run conditions. ( I. E.) Hot, Cold, Under A Load, Idling, Cruising.
1helpful
Why does my 1998 sebring idle fine but sputter badly under load.
Does it use spark plug wires or individual ignition coils for the each plug?. My 98 intrepid uses coils and occasionally I have to change them out cause it would start to miss when normal temperature was achieved. If it uses wires, try replacing them, along with the spark plugs.
My 1996 Ford Probe will crank but wont start. After 3 to 35 minute wait it will start. Sometimes it will drag the battery down and I have to wait for it to re-energize, then it will start. What is the...
Once you get your Ford to start, does the engine run normally ? If yes, then timing not an issue. If no, you may consider timing, but not until other components have been checked.
Have you done any maintenance to your vehicle like a tune up, air filter / fuel filter change. Have you checked fuel pressure ?
Have you checked for any codes in the engine control module ?
9helpful
2answers
2helpful
2answers
1.5L mitsubishi engine still missing/sputtering..etc
Ok there are several options such as water in the fuel or dirty fuel for starters. Another option would be clogged fuel injectors or a dirty map sensor. Check the spark plug wires to be sure that they are on tight and none are worn at contact points such as rubbing against a sharp edge. Let us know what the code(s) say.
1995 Jeep grand cherokee is missing while running. When it is under a heavy load (driving fast) it runs fine. When idleing and slow driving it spits and sputters.
I have the same problem on my 95 grand cherokee laredo. Sometimes it starts out fine and after about 10 miles it starts spitting and sputtering. Then after a while it seems to clean out and run fine again for a little while. Then other times it starts out spitting and sputtering at the begining. I changed the fuel filter and that was not it. It is a 4.0L 6cyc. Any Ideas?
Thanks,
Broken Arrow, OK
Several times our 95 Quest engine has died for no apparent reason while traveling. When this happens and we try to start it again it sputters and a groaning noise comes from somewhere under the vehicle...
Had the same problem with 1999 Quest - turns out that the distributor was going until it finally died. It stuttered andf kept shutting off when driven about 20 miles or so. Would start normally when cooled and off again when hot. But yours could be a different problem; not sure.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Suzuki Expert? Answer questions, earn points and help others
