Question about Sony DAV-X1 System
Audi but no picture when cable box conected through DAV-X1
I have connected my cable box to my new DAV-X1 using S-Video cables. I'm using a HDMI cable to connect to my Sharp Aquas 1080 LCD TV. I get cable station sound from the DAV-X1 speakers but no picture on the TV. When I play a DVD the picture and sound are superb.
How do I get a picture on my TV without connecting the Video driectly from my cable box to my TV?
Thank you.
  • tpulitzer Dec 29, 2007
    Same thing here please respond ASAP....
  • xrayja Jan 01, 2008
    My problem is similar. I am trying to hook up my cable box via S video (also tried standard video cable) through the DAV-X1 to my Pioneer Plasma using Component Video Cable. I can get sound, but no picture... Help
It won't work as the DAv can only output to HDMI by bringing singal into the HDMI input.
why wouldn't you send it directly to the TV and Audio to the DAV? I sounds like you don't have an HD box anyway (otherwise why would you use an analogue S-video cable vs component or HDMI). Unless there is a distance issue then go to the TV.
Posted on Jan 15, 2008
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
How do get sound surround interface between my HD SET TOP BOX and my Sony DAV-S300. I have seen previous responses and digrams with connection to the Optical in socket on my DAV but my system doesn't have...
The first two links you've probalbly seen before, they show conncections and connectors. I looked at pictures of your system and it would appear that the only input for video and audio is RCA. I think it has s-video for video only(s-video slightly better). The third link is the only way I can see to get what you are asking. It is an HDMI to RCA adaptor. You would use an HDMI cable out from your set top box to the adaptor then, RCA cables to your DAV-S300. It's the only way I can see. Hope this helps.
Mar 11, 2011 | Sony DAV-S300 System
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
I don't have a cable box and have hooked my Sony DAV-X1 system directly into the av input jacks on my tv. I can watch and listen to dvd's but the speakers won't work when watching tv.
What are you doing? Note the following:
The only cable you should connect to your TV from your X1 are the video cables
Logic is you want to use the system for sound and your TV for video only
  • If you have an LCD TV use the HDMI connection for video from your DVDs
  • If not the best video is using the component video (red green blue) i.e connect this to your X1 and your TV input
  • If your TV does not have this just use the video out composite (yellow). On the X1 it is indicated as Monitor
The reason why you do not have any audio from the TV is because you have not connected Audio Out from your TV to your X1. Do the following:
  • Identify if your TV has stereo audio out i.e A/V out should have red and white jacks
  • If this is the case connect this to your input on your X1 corresponding to TV
  • If your TV only has one Audio Out jack you need an RCU cable that has one to two pins and you would connect the single pin to your Audio out on the TV and the two (red/white) to your X1)
  • To listen to audio from TV simply set the input or source setting on your X1 to TV
Let know if this resolves your problem
Jan 10, 2010 | Sony DAV-X1 System
Need 5-digit code for universal remote on DAV-X1
There may be no code in the library of your Insight remote. You may have to try a different universal remote.
Apr 04, 2017 | Sony DAV-X1 System
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Dec 03, 2007 | Sony HOME THEATER SYSTEM System
Sony DAV-X1 System Logo
214 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
