Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
Changing panel display from farinheit (sp?) to celcius
Hi, I have a LG fridge model lrfd22850st that came with my new house but doesn't have a manual. Do you information on how to change the panel display from F to celius?
Thanks VERY much,
    New Friend:
  • 60 Answers
Hold the colder button for the fridge and the colder button for the freezer both for about 3 to 4 seconds. It should change to C.
Posted on Jan 03, 2008
Control panel not functioning properly. Displays 88 for all settings. Food in refridgerator freezing. Unable to change settings.
Remove power and wait for 3 minutes. And restart. or If any sensor or any plug in PCB board. Remove and reset it. Now try by restarting. Some times it will be helpful. If not problem with board. Replace it.
Jan 26, 2011 | LG LRFD22850ST French Door 22.4 Cu. Ft....
I have a honeywell thermostat magic stat/32 model 3200. It reads celis and not farinheit. Just started doing this.
Remove main stat from subbase. On back of main stat there are some screws used for different settings. Screw "C" if for fahrenheit and celcius. Screw in for fahrenheit and out 1 turn for celcius.
Jan 17, 2011 | Honeywell Heating & Cooling
Fridge not getting cold return air duct keeps freezing
make sure back and bottom of fridge is completely clean, if so you might be low on freon
Oct 23, 2010 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Water dispenser just stopped working. We changed the filter but made no difference. You could hear the new filter fill with water but when you press the dispenser button on the door nothing happens. LG...
This is probably a service call issue. The lines could be bad. The dispenser could be bad. You will be playing :poke and hope" and buying parts you don't need. The system is complicated and needs to be diagnosed by an authorized tech.
Jan 24, 2010 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Model LRFD22850 display says er and ff what does this mean
Failure of the freezer fan motor of fan motor circuit.
You may need a service call.
Make sure they are factory authorized for LG
Jan 13, 2010 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Please give me the URL for my new LG laptopPlease give me the URL for my new LG laptop manual. I would also like the page which tells me how to make desktop information larger than ''extra large.'' My...
you can change the font size of the screen on multiple locations
Accessibility in controlpanel ( start > settings > control panel)
Here you can alter contrast of the screen
or under display on the control panel > select the tab appearance and on the bottom you can select the font size
Jan 08, 2010 | Computers & Internet
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG will not defrost motor making a noise like ice hitting it
I had this issue as well, techs replaced the control board and problem solved. Mine was done under warranty during the first year, hope yours isn't too expensive.
Dec 29, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
372 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
