we are trying to print remotely through terminal services and cannot make it work
Comments:
Oct 09, 2009
- treminaled into a server, network printer 2844Z hooked up via network cable, i can see the printer as a choice but the print button is greyed out
Thanks for your help!
Need more info...are you terminaled into a server or desktop, is the printer a network printer hooked up via a network cable or is it shared via a pc it is connected to. In the terminal services manager, does everyone have permission in session to use the printer (manage print jobs), do the users see the printer as available in their term session?
Terminal Services should map to a local printer, you will need some adjustment to the Terminal Services manager to set the map to the server to which the printer is attached.
Was this helpful?
Yes
No
Popular Solutions for Zebra TLP 2844-Z Thermal Label
I have a Tlp 2844 printer which doesn't want to print, the following error came up : Error...
(More)
I have a Tlp 2844 printer which doesn't want to print, the following error came up : Error encoutered during printing
TLP 2844-Z doesn't print label barcode in 30 x 1,5 mm I have installed Zebra Designer to make a...
(More)
TLP 2844-Z doesn't print label barcode in 30 x 1,5 mm I have installed Zebra Designer to make a barcode in a paper with this specification: single label 30 mm Width 15 mm Height every rows are made by 3 label (horizontal) with 100 mm Width 2 mm Left Margin 2 mm Right Margin 3 mm X Gap 1,5 mm Top Margin 1,5 mm Botton Margin infact 3 x 30 + 2 + 2 + 3 + 3 = 100 mm = Row width the problem is when i try to print this label the number of the feed is right but the label are completely blank for example if i try to print 9 label (= 3 row) the printer do 2 feed but nothing appear in the label i have tried to print the printer setting with this label format inside by the instruction in the manual and the info are correctly printed (for me is not a problem of paper or ribbon) i have tried to re-install the driver for Zebra Designer after downloaded it by zebra Home site the file ZD1510Certified.exe and setting the driver ''ZDesigner TLP 2844-Z'' nothing changed. what is the problem?? and the solution?? Thank you in advance for your help and assistance.
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have...
(More)
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF and the i need to take print. I need to take print directly from the application. Kindly assistance me. Regards, Ramesh ramesh.perumal@csscorp.com
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink...
(More)
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink red light am currently running windows xpsp2
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
