Question about Sony Cyber-shot DSC-W55 Digital Camera
Canon what is the red flashing camera in the lower left hand corner when the button is pressed?
  • Sony Master
  • 4,738 Answers
It should also have two red hands gently cupping the camera from below. It's just telling you that you're in a low light situation. With the current mode setting of the camera (night scene, no flash, etc...) you'll need to hold the camera extra steady to avoid a blurred picture.
Posted on Dec 25, 2007
Over exposed photos
Could you please upload a sample pic ans its exif
Dec 18, 2013 | Canon PowerShot S5 IS Digital Camera
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
I have just purchased Canon Powershot A480
I think the "busy" part can be put down to the camera performing a function or recharging the flash. The red icon I THINK shows that the camera is focussing.
With the last model it worked so that you could half press the button to focus on something (eg a fast moving pet) and then once your pet stopped moving your could fully press the button to take a photo and the focus distance would remain the same.
Nov 27, 2009 | Canon PowerShot A480 Digital Camera
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Canon sd 750
Hi
It means that there is not enough light and your camera needs to be supported due to the long length of time the aperture needs to be open to get a decent picture.
Set your flash to 'Automatic' and it will flash in these low light conditions and you won't get blurry photos.
Good luck from Darntoothysam com
Thomas
Sep 28, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Flash not working
i think your problem is that you are not flipping open the flash... the flash doesnt automatically flip open... and the blinking red icon in the lower left just means that since there isnt enough light, the camera will spend a bit longer to allow more light to enter the lens, hence you need to keep the camera steady and not shake it... hope this helped
May 20, 2008 | Canon PowerShot S5 IS Digital Camera
Canon powershot A640
Try turning the camera on and pressing the DISP button once (button in the lower left corner).
Mar 09, 2008 | Canon PowerShot A640 Digital Camera
Black screen
you probably just pressed the DISP button on accident (its on the lower right hand corner of the screen) to turn the screen back on, push the DISP button. if that doesnt work, i would get it looked at by people at Canon.
May 03, 2007 | Canon PowerShot A520 Digital Camera
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
55 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
