Question about Dacor ECS230 Epicure Electric Double Oven
Bottom oven of dacor double oven
Bottom oven won't heat. Power seems fine. Top oven is working fine. Bottom oven goes to preheat but doesn't heat.
  • 3 more comments
  • dmfnc Feb 25, 2008
  • tiredofdacor Apr 30, 2008
    Bottom oven won't heat (indicates that it is preheating, but doesn't get warm). The light comes on as well. The top oven seems to work fine. The same thing happened 8 weeks ago. Paid about $100 for a service call and was told the circuit tripped. I can't seem to find the circuit breaker inside to reset it.
  • Anonymous Mar 13, 2014
    CDA DC730 Double oven. After power cut, bottom oven will not heat even though the fan is turning
  • Anonymous Mar 17, 2014
    while using oven yesterday it caused the power to trip and now it won't heat up
  • Anonymous Mar 27, 2014
    After cleaning, oven will not heat
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
I had to replaced the thermal fuse in my double wall oven top oven now works fine but the bottom oven does not heat up what could be the problem?
Hello Mr Samuels,
Do you have the model number of your oven? I'd be happy to help.
Please email us at info@fixyourboard.com
Jun 04, 2017 | Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Top oven works fine bottom oven won't heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor Electric Double Oven - bottom oven won't heat
If ti has a timer that is flashing auto, reset it to manual , as it will not work in auto mode.
Hope this helps.
Plz rate soltuioun.Thanks
Dec 26, 2008 | Ovens
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Dacor ECS230 Epicure Electric Double Oven Logo
804 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
