Question about Sony Playstation 3 (PS3) Console
Ps3 it was playing ps2 game put in a ps3 game in it want load and will i power it down and try to restart it it said can not start hard disk not found
    Problem Solver:
  • 10 Answers
U have to reinstall the game in hard disk or try again.
Posted on Dec 25, 2007
Sony PS3 ERROR CODE 80710092?
80028EA8 - Seems to mean unable to authorize isp account details
here are some of the ps3 error code that might help you in the future..
Complete PS3 Error Codes:
0710102 - DNS Error; No DSN server available.
8013030 - System Error due to failed update download
80010001 - Major Error , Game ability stopped
80010006 - An error occurred during the start operation (corrupted folding install)
80010007 - An error occurred during the start operation (during disc swap tests)
8001000B - it happens when trying to establish wireless connection
80010017 - Can't start BlueRay Game
8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown
8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
8001050F - Hardware failure. Cannot update firmware or connect to internet.
80010510 - Will not play games installed on the hard drive
80010514 - Possibly reading blu-ray disc problem
80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
80023101 - Unknown
80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server
80028EA5 - User cannot connect to PS3 network
80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.
80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,
80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again
80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
80029023 - Exchanging Key Information exchange has timed out
80029024 - "The attempt to obtain an IP address has timed out".
80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)
80029501 - connection
80029509 - When the PSN network is down for maintenance.
80029513 - This content cannot be accessed on your account (80029513)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)
80029564 - Downloaded game will not install
80029751 - warhawk wont start but eveything else seems ok
80029945 - Can't playback burn BD movie
80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )
80029C68 - Corrupt data usually on external device
8002A10B. It shows up when I try to view my friends trophies, profile etc.
8002A10D - Unable to Add friend in XMB
8002A4A6 - Cannot load game to play online
8002A515 - Error Signing in
8002A524 - connection
8002A548 - Unable to remain logged in - either to game or server
8002A705 - Unable to connect to server/host. Check router port configuration.
8002AD23 - Unknown
8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.
8002B241 - DVI has no audio.
8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
8002F994 - Too many people downloading the update (download it later on)
8002F997 - Can not update XMB firmware
80030001 - Deleting messages from inbox
8003041F - An error occurred during the copy operation (using media server)
80030517 - It seems to happen when you copy large media files.
8003051E - Game will not save
80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)
80031150 - "Setting information is corrupted.Press the x button to repair and restore default"
80031601 - Error Creating Account
8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none
8013013D - connection
8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
8013030F - Access Point not detected
8041040F - Communication with the server failed. A dsn error has occured.
80410418 - DNS Error
80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
80710016 - Playstation Network is down.
80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"
80710101 - Connection error
80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection
80710541 - The connection to the server timed out.
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode
81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
Mar 01, 2011 | Sony PlayStation Portable (PSP) Console
Tip
PlayStation 3 ERROR CODES
Complete PS3 Error Codes:<br /> <br /> <br /> 0710102 - DNS Error; No DSN server available.<br /> <br /> 8013030 - System Error due to failed update download<br /> <br /> 80010001 - Major Error , Game ability stopped<br /> <br /> 80010006 - An error occurred during the start operation (corrupted folding install)<br /> <br /> 80010007 - An error occurred during the start operation (during disc swap tests)<br /> <br /> 8001000B - it happens when trying to establish wireless connection<br /> <br /> 80010017 - Can't start BlueRay Game<br /> <br /> 8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown<br /> <br /> 8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again<br /> <br /> 8001050F - Hardware failure. Cannot update firmware or connect to internet.<br /> <br /> 80010510 - Will not play games installed on the hard drive<br /> <br /> 80010514 - Possibly reading blu-ray disc problem<br /> <br /> 80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again<br /> <br /> 80023101 - Unknown<br /> <br /> 80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server<br /> <br /> 80028EA5 - User cannot connect to PS3 network<br /> <br /> 80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.<br /> <br /> 80028EA8 - Seems to mean unable to authorize isp account details<br /> <br /> 80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,<br /> <br /> 80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again<br /> <br /> 80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).<br /> <br /> 80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it<br /> <br /> 80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error<br /> <br /> 80029023 - Exchanging Key Information exchange has timed out<br /> <br /> 80029024 - "The attempt to obtain an IP address has timed out".<br /> <br /> 80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)<br /> <br /> 80029501 - connection<br /> <br /> 80029509 - When the PSN network is down for maintenance.<br /> <br /> 80029513 - This content cannot be accessed on your account (80029513)<br /> <br /> 80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)<br /> <br /> 80029564 - Downloaded game will not install<br /> <br /> 80029751 - warhawk wont start but eveything else seems ok<br /> <br /> 80029945 - Can't playback burn BD movie<br /> <br /> 80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )<br /> <br /> 80029C68 - Corrupt data usually on external device<br /> <br /> 8002A10B. It shows up when I try to view my friends trophies, profile etc.<br /> <br /> 8002A10D - Unable to Add friend in XMB<br /> <br /> 8002A4A6 - Cannot load game to play online<br /> <br /> 8002A515 - Error Signing in<br /> <br /> 8002A524 - connection<br /> <br /> 8002A548 - Unable to remain logged in - either to game or server<br /> <br /> 8002A705 - Unable to connect to server/host. Check router port configuration.<br /> <br /> 8002AD23 - Unknown<br /> <br /> 8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.<br /> <br /> 8002B241 - DVI has no audio.<br /> <br /> 8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game<br /> <br /> 8002F994 - Too many people downloading the update (download it later on)<br /> <br /> 8002F997 - Can not update XMB firmware<br /> <br /> 80030001 - Deleting messages from inbox<br /> <br /> 8003041F - An error occurred during the copy operation (using media server)<br /> <br /> 80030517 - It seems to happen when you copy large media files.<br /> <br /> 8003051E - Game will not save<br /> <br /> 80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)<br /> <br /> 80031150 - "Setting information is corrupted.Press the x button to repair and restore default"<br /> <br /> 80031601 - Error Creating Account<br /> <br /> 8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none<br /> <br /> 8013013D - connection<br /> <br /> 8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security<br /> <br /> 80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.<br /> <br /> 8013030F - Access Point not detected<br /> <br /> 8041040F - Communication with the server failed. A dsn error has occured.<br /> <br /> 80410418 - DNS Error<br /> <br /> 80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.<br /> <br /> 80710016 - Playstation Network is down.<br /> <br /> 80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"<br /> <br /> 80710101 - Connection error<br /> <br /> 80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router<br /> <br /> 807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error<br /> <br /> 8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection<br /> <br /> 80710541 - The connection to the server timed out.<br /> <br /> 80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ<br /> <br /> 80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured<br /> <br /> 80710B23 - PS3 Network is Down or PS3 Network is too busy to respond<br /> <br /> 80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode<br /> <br /> 81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
on Feb 06, 2011 | Sony Playstation 3 (PS3) Console
Ps2 can store any full game on using hard disk ?
it depends on what type of Ps2 you are using.. the model varies depending if it has space for hard disk storage.. i have here multiple models of it where you converted it to play the game to the hard disk
Mar 08, 2010 | Sony PlayStation 2 (PS2) Console
60GB PS3 will play PS1 and PS3 games but not PS2.
this is a problem with some ps3's especialy the high GB ones like mine. they made it so most if not all of the ps2 games cannot be played to cut down on price and to leave room for all the memory. so you can still play ps1's but you cant play ps2's. sorry
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will load ps2 games and play them but when i put a ps3 game in it wont even load it ? it was ok yesterday
HI,,
PS2 DOESNT SUPPORT P3 GAMES...
LENSES DIFFER FROM EACH OTHER..
NEED PS3 GAMES TO PLAY WITH PS 3
PS2 GAMES TO PLAY WITH PS2
TNKS
RABBANEES
Nov 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 problem - Wont recognise or load PS3 game disks
swich back and forth between the ps2 game and ps3 game or just keep putting in the ps3 game until it reads it. your laser is probally going.
Oct 05, 2009 | Sony Playstation 3 (PS3) Console
My PS3 will start to load Call Of Duty 5 then just goes blank..But will play other discs.Any Ideas?
When I had a similar issue with my PS2 (GT4 would not load) it was because the disk-reading laser was misaligned. That happened after using the system for many years, so if your system is new, maybe you can skip to the 2nd part of my answer. A slight misalignment could mean that the disk is still read, but the process takes longer. If COD5 requires frequent access to the disk when booting up - as GT4-, that might explain why other games load properly and COD5 doesn't.
Other potential problems: scratched disk (visible scratches), dirty disk (you can clean with a cloth, sweeping radially from the center to the border of the disk), problem with the COD5 data installed in your PS3 hard disk (try reinstalling the game).
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 14, 2009 | Sony PlayStation® 3 (60 GB) Console
Disk tray won't stay in
Your PS2 is definitely broken. Either send it in to Sony to be repaired or buy a new PS3. Bummer. Sorry to hear about this.
Dec 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
