Question about Maytag MSD2756G Side by Side Refrigerator
Ice not getting through the door
When press the ice button then place the glass on the shelf, the ice does not come out the door, it backs up in the door. There is a round thing that should open at least I think so. any Idea's ??
    Scholar:
  • 66 Answers
Seems that the door is jammed or frozzen.
Posted on Dec 28, 2007
Out loading auger problems
if by this your saying that the ice dispenser auger has a problem ?
a few things to look at on a ice dispenser
1st remove ice bucket with auger completely out of fridge
look at back of fridge is there a build up of ice there ? if so you may have a leaking water valve for ice maker
carefully inspect the back of ice bucket to see that drive catch is not broken or missing parts
2nd verify that the door to side that contains the dispenser is all the way shut , sometimes ice build up keeps door from closing all the way to allow door switch to say ( door closed safe to dispense ice) this switch is not allways at top or bottom of door but maybe in the middle too
and last but not least , make sure all switches and childlock outs are set correct to working positions and that glass sensors detect the glass in its place
Nov 14, 2015 | Refrigerators
The ice and/or water won't stop coming out the door when the back soft panel area is pressed. Either ice or water keep coming out when the back is pressed with a glass until door is opened. When the door...
It sounds like the actuator for your dispenser switch is sticking. To fix it you will need to get inside the dispenser housing, which involves removing the decorative front panel on the dispenser.
It's kinda tricky to get this thing apart, and it's even harder to get it put back together if you've never done it. I'd recommend calling a repairman.
Sep 28, 2010 | LG LRSC-26922 Side by Side Refrigerator
When you press the ice dispenser no ice
the switch you push activates a couple of things. One is a solenoid that opens the door the other is a relay that moves the ice to the crusher.
Since you aren't hearing any sound....and are not getting any ice, I would suspect the switch is bad.....
But before you start taking things apart....try pushing it with your finger rather than a glass.
Check for the length of travel? can you feel or hear a switch click?
Jul 07, 2009 | Frigidaire FRS6R5ESB
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker will not disppense ice on my Samsung RS2534ww
SOUNDS TO ME THE TRANSPORT AUGER MOTOR NEEDS REPLACEMENT. JUST MAKE SURE THAT ON THE CONTROL PANEL, THE CHILD INTERLOCK IS NOT ON WHICH STOPS ICE DISPENSING OPERATION. JUST DONE ONE NOW WITH THE EXACT FAULT.
Jul 14, 2007 | Samsung RS2534 Side by Side Refrigerator
Roper RS22AQXMQ00
When you try to get ice does it make any sounds (clanks, whirring, grinding,etc.) like something is happening inside or is it just quiet? If quiet, see if you can look up inside the door switch area with a flashlight and press the button with your finger instead of the lip of a glass. Post more info when you have it and we'll go from there.
Dec 11, 2006 | Roper RS22AQXKQ Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
44 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
