Question about LG HBM 730 Bluetooth Headset Wireless Headset
Not connecting When I try to connect the LG HBM 730 to my LG 8700 phone it tells me "device out of range or turned off" when it is right next to me and turned on with a fully charged battery. Any suggestions because this is driving me absolutely crazy!?
  • 1 more comment
  • acinglj Jan 18, 2008
    I've got the same problem. LG 8700 phone...LG HBM-770 Bluetooth headset. Once they're paired and connected they should automatically disconnect and reconnect when needed (distance/charging/etc). Instead, I have to usually turn on the head set, turn off the phone, restart the phone and then connect. Then if I plug either one into the charger it's hit or miss whether they will auto-reconnect. Sometimes when I'm on a call it will go silent and the phone will report "audio transferred to phone" so I open the phone and try to continue my conversation and the audio will jump back and forth between the phone and headset. Please help!!
  • itscari Apr 02, 2008
    I've been having the same problem exactly with my bluetooth, they have replaced the phone and bluetooth and it is still happening. I think it's the model of the phone LG 8700.
  • Anonymous Jul 28, 2008
    the 8700 is a piece of **** in many ways. I've had the phone replaced and still many bluetooth problems
I was having a problem getting my hbm-730 to connect/turn on with my enV. i took the suggestion of turning phone off and then turning it back on. i had already removed the device from my phone thinking i had to reprogram it.
when i turned the phone back on, i was able to pair up my bluetooth with my phone with no problem. now, we'll see what happens next time.....but that worked for now.
Posted on Feb 25, 2008
The only real solution is to have Verizon replace the 8700 with a NEW one, not a refurbished one, which is what they normally do. Clearly this phone suffers from manufacturing/design problems relative to the Bluetooth. I have had mine replaced 3 times now, and the Bluetooth replaced twice. Getting a totally new phone will, however, only buy you 3 or 4 months of relief.
Posted on Aug 17, 2008
I had the same problem with a VX5400. *228 send to reprogram the phone fixed it for the moment.
Posted on Aug 07, 2008
I have found that if you reprogram your phone if you have Verizon. (*228 send) it will link up. Hope this helps.
Posted on Aug 03, 2008
Posted on Jan 18, 2008
LG HBM 310 will not connect to to my new Blackberry 9550. I am entering 0000 as required.
You must put your headset in pairing mode first. Starting with it turned off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Nov 17, 2010 | LG HBM-310 Bluetooth Headset
My HBM 210 lg bluetooth not working
LG HBM 210 WONT CONNECT WITH MY MOTOROLA DROID
Nov 20, 2009 | Cell Phones
I lost instructions on how to pair my lg bluetooth hbm 310 to my cell phone and my phone is asking for a passkey where do I find it on my blur tooth?
You must put your headset in pairing mode first. Starting with it turnedd off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Regards, Carlos
Nov 01, 2009 | LG HBM-310 Bluetooth Headset
Headset
you haveto have the bluetooth connectivity serch for th device. one the device is found then your phone can be linked to that bluetooth adapter.
Jul 15, 2009 | LG HBM-710 Wireless Headset
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
My LG HBM-730 does not connect to cell phone
I powered down both my cell phone and bluetooth earpiece. Attempted to reconncect and it worked immediately.
Jan 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Can pair, can't connect
maybe its already connected to another device, try disconnecting from the other device, then connect it to the one you want to
Feb 22, 2008 | LG HBM-710 Wireless Headset
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
I can set up my headset to my new phone
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 Bluetooth Headset Wireless Headset Logo
242 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
coolboyjitu
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
