Question about Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range
Matag MER5552BAW Right from the start my oven door lets so much heat out over the top of the door that it has stained the top edge of the door kind of a carmel color from the heat. I have tryed taking the door off to see if it is on right but there seems to be only one way it does fit. I looked at other new ones just like it in the store and they all seem to fit the same. Since I can't get the heat to not do that - how can I remove the icky color from the edge? This was a brand new stove a year ago and because of this discoloring - it looks older than the 20 yr old one I got rid of!
  • kazul Dec 25, 2007
    Thanks but I did try that solution. Its more of a discoloration from the heat than any build up of anything. I looked at the springs and the seal and they seeem to be the way they are supposed to be. The door really only feels shut tight when you use the lock for cleaning the oven but of course then you can't use the bake setting.
  • jmat Dec 31, 2007
    I have the same problem. When you use the self-cleaning feature, the heat leaving the door through the slits on the top of the door and around the top lip of the leave a thick brown residue that will not come off regardless of the type of cleaner used and the amount of scrubbing applied.
  • 640 Answers
You can try clr (calcium lime rust) remover.i would check the tension of the springs on the door hinges are set properly (if there there) or the seal on the door.merry christmas
Posted on Dec 25, 2007
I have a Maytag electric oven model MER5552BAW. Bottom bake element blew out. I replaced the element & now oven will not heat at all. Going nuts!
Go to youtube and type in your model number and ask for repair videos:
Feb 20, 2015 | Maytag Kitchen Ranges
Hey friend, thank you for your inquiry!
I understand that your Electrolux range has yellow stains on the top of the door. Typically you should just use warm water and mild soap to remove any stains on your range. If that does not help to correct the issue I would suggest a touch up paint that can by typically purchased through your manufacturer or replacement of the door. I hope this has been beneficial. -Matt
Oct 16, 2014 | Electrolux Frigidaire Oven Temperature...
White spots on exterior of microwave door glass
Exterior or interior? If they are on the exterior then something unassociated with the oven has caused them. If they are between sheets of glass then could be silacone fume residue or if it has a clear plastic filter on the inside of the glass, could be that. If they happen to use laminated glass, it could be the plastic middle but I doubt they would. Radiation leaking from microwave ovens is really a bit of a myth. Yes, if you have a damaged seal and there is a big enough gap, microwave radiation can leak out but unless you are hugging your oven, it's no real drama, according to current medical experts.
May 05, 2017 | Kenmore Kitchen Ranges
How do you clean moisture stains from between the door glass?
If they are stains, not too much can be done except for taking apart the glass and cleaning. If it's just moisture, you can shine an auto/shop trouble light (the old kind that get warm, not the new flourescent ones) on it to slowly heat it up and dry it out. Be careful not to get the door glass to warm or it may warp. Best is to just get it a bit warm and keep the light on it for several hours.
Jan 31, 2011 | Microwave Ovens
Element in oven sparked at corner and now will not heat
The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
How to install a hancle on the oven door of a matag range?
Ok open the door to about 1/3 of the way the door will rest there when you let go. Now pull straght up on the door. The door will slide right off. Pull the screws out that hold the door together. look at the bottom of the door then look on both sides for screws. remove them all. Pull the door apart and you can get to the screws that hold the handle on.
Good Day Hope this helps.
Aug 26, 2009 | Kitchen Ranges
Oven vents on front are stained and ugly. How do I clean them?
sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Stain inside double glass microwave door
most microwaves have screws on the top and bottom outer lip edges. or under the rubber grommet if it has this .
but this unit should have a 10 year warranty and they may cover this issue call them
Feb 29, 2008 | KitchenAid KEHC379 Electric Double Oven
Oven door will not seal at top.
The same thing with mine. I took apart the door today and found the hinges a little bent. I think it should be ok to bent them the opposite way a little with some mole grips......and then I must remember not to move the stove out for cleaning by the oven door handle again (oops).
Door comes off (unlock hinges and lift up). undo 4 screws on the bottom edge and then two on the inside of the door handle then it comes apart - beware as it's heavy. The hinges themselves come off with two screw each.
Jan 27, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range Logo
180 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
