Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
"no CF card"
I've got a good CF card in my camera but am still getting the above error message.
suggestions?
    Novelist:
  • 148 Answers
Try reformatting the card. otherwise you either have a defect in the card that does not manifest itself while not in the camera, or you have a broken pin in the cf slot. look down it to see if all the pins are upright and none missing. next, you can try another cf card. if you get the same reading then its the camera.
reset the camera by removing the main battery and reinstalling it. if that does not work, then you will likely need to send the camera for repairs. if you have broken or missing pins, it will also occasion a repair shop visit.
good luck
mark
Posted on Dec 24, 2007
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
I keep getting error 99. I've cleaned the sensors with a new eraser; I've changed the battery and changed the memory card. If I take out the battery and put it back in, I can take a picture. If I pause for...
Hello:
Here is what Canon said :
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help
please don't forget to rate !
Mar 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Can this Olympus C5050Z works with Sandisk CF Ultra 4GB 30MB/s? I tried to insert it, and always gets card error message, although I can use the card in my notebook.
Your camera was designed to be fully CF compliant, but it was designed long before 4GB cards were available so your problem is likely to be that the camera cannot handle a card of that large a capacity.
I've checked the Olympus servicing manual but unfortunately it doesn't state a maximum CF capacity and there have been no relevant firmware updates to extend CF compatibility.
When your camera was released back in 2003 the largest capacity CF card was 1GB so I suggest that you don't go above that size. You'll also be wasting your money on any more than a regular Sandisk Ultra as the camera cannot take advantage of the faster data transfer rates of later cards, I'm not even certain that it can utilise the speed advantage of an Ultra over a really basic model, but it won't cause the camera to throw it's toys out of the pram either.
I hope that you've found my reply to be of use and ask in return only that you return the goodwill and rate my answer.
Nov 23, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
Error message 99
ouch ...look inside the camera where the CF plugs in .. you may have a bent pin ... some CF cards have a nice lead in taper so it centers the pins as you plug it in .. but some have hardly any taper (no idea why they make some this way) .. if the pin is off just a little with such cards then it bends the pin ... you might see a mark on the CF connector where the pin hit ... also if the card is forced in backwards or out of position you can bend pins ... i have one really nice camera that has 12 missing or bent pins .. someone tried to plug in an adapter that was poorly made (over and over) backwards and forwards .. that camera is spare parts now ..
Sep 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CF Card
Please post back the error message you notice.
Mar 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
"card error"
Have you tried formatting these cards in your camera? You will find the setting in the menu as per page 26 of the manual. Also check that the correct card type is set for xD or CF as appropriate. You can download the manual from the link below: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Olympus EVOLT E-500 Digital Camera
CF Error
I had the same symptoms. I took it to an authorized Canon repair shop. For $150, they resoldered connections on my 'power supply board'.  No idea why the solder gave out. It's working great now.
Jul 09, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
103 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
