The camera isn't seeing the card inserted.
Have you tried another compact flash card in the slot to see if your camera is definitely at fault?
If so get a maglite and examine the slot the card plugs into and check none of the pins are bent. If there is a bent pin you may be able to straighten it with a pair of tweezers, though you may need to dissasemble the camera to do this. If the pins are all ok then you may have a board fault and while this is fixable it requires patience, a steady hand, knowhow, and test equipment. It would be easier to search for a scrap camera of the same model on ebay with a working board (search for one with a broken screen or lens) and simply swap it out.
Of course before you do any of these things check if your manufacturers warranty is still valid.
