Question about HP LaserJet 3380 All-In-One Printer
Scanner is scanning to a large file,how do I change the settings? PDF is too large to convert
  • oobynut Oct 09, 2009
    When document is scanned the default pg.sixe is 42x36 so when I try to convert with my program to a word doument I rec.error mess.document too lg.to convert,is there some registry edit that controls the default pg size when a pdf is created that might have been changed on my comuter? WE looked up settings for HP & couldn't find any to make pg smaller
  • dekmacto May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Lexmark Printer Solution
    » Epson Printer Solution
    » Brother Printer Solution
    » Dell Printer Solution
    » Canon Printer Solution
    » HP Printer Solution
    » Kodak Printer Solution
    8
PegBox60965
  • 51 Answers
SOURCE: Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Posted on Dec 31, 2008
  • 2692 Answers
SOURCE: How to scan multi-page documents (text) into a single pdf file?
You are welcome.FIx Ya?
Posted on Jan 21, 2009
SOURCE: scanning a doc to a pdf doc.
Go to this link to download a free software pdf converter you can use.
http://www.topshareware.com/download.aspx?id=38468&p=&url=http%3a%2f%2fwww.verypdf.com%2ftif2pdf%2fimage2pdf_ocr_setup.exe
Posted on Feb 10, 2009
  • 18 Answers
SOURCE: Scans are too large...
while scanning try reducing the DPI of the scans. this will make the image smaller in size but it will effect the picture quality very little. but do keep in mind that the dpi must be atleast 70 for better picturization
Posted on Jun 28, 2010
  • 96 Answers
SOURCE: will not scan as pdf file--choices are jpeg, tiff, etc. no c
You have to use the conversion program in your computer first to convert to PDF
Posted on Jul 27, 2010
Slow save on pdf file with capture perfect3
Change the scan resolution to 200 dots per inch (200 dpi). If 300 it tajes a few seconds. If 1200 dpi, it may take really long.
Jul 29, 2014 | Canon DR-9080C Path-Through Scanner
No pdf format on scanner file type
You can scan document to multi-page TIFF file anf then use a TIFF to PDF Converter to convert all pages from the TIFF document to PDF file.
Jan 21, 2013 | Canon Pixma MP480 All-In-One InkJet...
Scanned documents' size is too large (the least I got was 600kb), how can I scan a document to a PDF with the normal size of 200kb?
You need to install a PDF writer program first. There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
Scan your document the click on File - Print and select the PDF writer as the printer device. Then name and save the PDF file.
Feb 09, 2011 | HP Scanjet 5590 Flatbed Scanner
File conversion error word 2003
Install word converter package it will work
Feb 03, 2011 | Microsoft Office Word 2003 for PC
I own a brother mfc 7840W and want to scan to a word file then convert it to a pdf how would I do this?
hello there
first thing, scan the document and when you typed the filename below that box is option, you can select what extension name you want to that file select pdf and click save. be sure you have pdf reader or acrobat reader etc..
Thanks
Nov 13, 2010 | Brother MFC 7840W Printer
How can I switch my scans from JPEG to PDF format without using a USB? I just got a new laptop and have my scans going direct to a folder on my computer but I want PDF files not JPEG. Do I really need to...
I dont agree with the first solution We have lots of these multi function printers at work and you can easily change the scanner output to PDF from the options menu including resolution, multi page etc. seach the manual for this option but the printer is certainly capable
James
Nov 08, 2009 | Dell 1815dn All-In-One Laser Printer
Pdf files are to large to email when scanning
copy the pdf text to a word document and relax!!
Jun 20, 2009 | Lexmark X8350 All-In-One InkJet Printer
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
SCAN ORDER
This is almost impossible! THe scanner will scan only one page/image at a time and immediately stored. The roller can pickup only the top page. Are you converting them to a multipage PDF file? Is there any setting in creation of PDF file? If problem still persists, try and reinstall the software after uninstalling the existing version.
S. Mohan
Jul 22, 2008 | Canon DR 3080C Path-Through Scanner
HP LaserJet 3380 All-In-One Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
